Old 09-15-2004, 01:37 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
How much did it cost you???
For the newbies out they please post a break down of how much your CNC wood router machine cost you to build. Post the cutting area and the type of control (servo, stepper) and software. Also how many hours it took to complete it.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 09-18-2004, 09:59 AM
samualt is on a distinguished road
Total Cost: $4000 Hardware
Cutting Area: 4'x8'x10"
Servo Motors: 3 motors at 1500 ozin peak, nema 42
Controller: 3 x Rutex Controllers with motherboard and IO card.
Frame: Aluminum T-Slots
Linear Bearings: THK Rails on all three axis.
Actuators: 2 ball screws, 1 rack-and-pinion
Hour to complete: One Year
Plans: My own design
Software: Rhino 3D, Visual Mill, Mach2
Actually, I'm just finishing mine, but I finally got all the parts. Add another $500 for tools, and another $500 in mistakes. If I had used plans I could have done it in 3 months at a slightly higher price. I spent much of my time just gathering parts on ebay at the "right price". I'll post a web page about it when I done (this month).
Old 09-18-2004, 12:30 PM
Gold Member
marvinstov is on a distinguished road
Total Cost: $418.00
8 Drawer Slides - $100
1 Sheet MDF - $35
3 Stepper Motors w/cables - $65
1 Xylotex 3 Axis board - $130
6 feet of 1/4" - 20 Allthread - $6
Drywall screws & glue - $8
Turbocnc Software - $20
Computer & Monitor (133 Pentium) - $15
Dremel Tool - $39
Completion time: Two Weeks
Plans: Own Design
Old 09-20-2004, 09:15 AM
rc-cellar is on a distinguished road
Made first cut this weekend !!!
Useable travel 30x20x8"
Router table is painted 3/4 MDF, 4x4 legs
THK KR46 slide/actuators
THK 25mm linear rails
Clifton Precision 360oz/in Servos
USDigital 250 line encoders
Homemade servo controller -
Gecko G320's on heatsinks
Axxus breakout board
35V/25A power supply
Dell 400MHz laptop running Mach2 (demo)
Bosch 3/4hp laminate trimmer
Total cost under $3000 (thanks to Ebay)
If it ain't broke... fix it 'til it is.
Old 09-20-2004, 09:18 AM
more pics
ID:	3453   Click image for larger version
ID:	3454   Click image for larger version
Old 09-20-2004, 02:14 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
Total Cost: ~$3500
Cutting Area: 28" x 24" x 8"
Powered by: (3) 430 oz/in Servos (2:1 ratio for 860 oz/in) & Gecko Drives
Power supply: 36 VDC @ 25 Amps
Construction: Gantry style, All solid aluminum, THK Linear bearings
Lead screws: Rolled 5/8" .2 pitch ball screws and nuts in all three axies
Time to complete: about 8 months or less.
Plans: My own design.
Software in use: Mach 2, MasterCam, ArtCam, SolidWorks, Cadkey
I only can find a un-finished picture of my router. Guess I need to take some pics
ID:	3456   Click image for larger version
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 10-29-2004, 01:12 PM
studysession is on a distinguished road
Mine was 1200 pounds exc VAT. Bought from a company in Scottland - http://www.simplycnc.com
Please check out my CNC blog
http://cncinside.com
Old 11-06-2004, 03:07 PM
Redline's Avatar
Redline is on a distinguished road
Thumbs up
It cost me about :1400-1600$ give or take
Linear rails with bearings EBAY 250$
FET3 Cruiser package Stepper World 379$
3/8-16 stainless steel lead screw 20$
Dremel 40$
Porter Cable Router EBAY 50$
Compaq Presario with XP on sale 400$
Mach 2 150$
Steel for table and brackets scrap yard 25$
Nuts and bolts 15$
Z-axis was salvaged from the dumster at work
Lead nuts cast and machined from bronze at home
Any other little bits I made myself
The useable work space is 17x28x6
IPM about 12
All steel construction very rigid and very heavy
I use it mostly for engraving and foam cutting for LFC
I am happy with it
Low cost machining centre retrofit motordude General Metal Working Machines 2 01-07-2005 02:32 AM
Cost and feasibility of a new operation. Laff Riot Casting Metals 2 08-23-2004 02:15 PM
The cost of motion Jcadwell DIY-CNC Router Table Machines 11 04-22-2004 09:18 AM
Cost of OneCNC XP Alan T. OneCNC 1 08-31-2003 04:10 PM
Low Cost Ideas or Experiences? coherent DIY-CNC Router Table Machines 13 05-10-2003 04:22 PM
