Old 06-25-2008, 09:56 AM
Rickv100 is on a distinguished road
HDPE acme nut
I built some acme nuts out of HDPE for my JGRO router and they seem to have a good amount of drag in use.
Any suggestions on lapping or other methods to reduce the drag?
I can turn the acme rod with a wrench on an acme nut but there is a good amount of resistance.
Rick
Old 06-25-2008, 10:13 AM
Did you tap these nuts the way I have seen described by using a piec of the threaded rod?
HDPE is flexible and even with a regular tap tends to 'flow' around the cutting edge so the thread comes out a bit small.
One thing you can try is put the nuts and tap in a deep freeze to get them as cold as possible and then retap the thread. The HDPE will contract much more than the metal and will become a bit more rigid so there is a good chance a bit more will be cut out. It will still be tight at the low temperature but once it warms up shold be looser.
Old 06-25-2008, 01:48 PM
Yes and no, I did tap the HDPE using a piece of Acme rod made into a tap but I did not freeze them prior to tapping, I will give that a try.
Rick
Delrin or HDPE, which did you use? Glidergider DIY-CNC Router Table Machines 20 07-22-2010 09:14 PM
Engraving HDPE Nick1983 General Metalwork Discussion 6 04-25-2008 04:16 PM
HDPE Bearings jhowelb Linear and Rotary Motion 28 03-04-2008 03:45 PM
Best Supplier for HDPE? dshowalt Glass, Plastic and Stone 4 08-19-2007 10:52 AM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 06:47 AM
