Old 06-25-2008, 07:52 AM
jeff1424 is on a distinguished road
Newbie: Looking for plans
Hello all,
Is there a good source of plans out there that will allow me to build a slightly bigger unit? Maybe a 3'-4'X4" table.
Jeff
Old 06-25-2008, 08:52 AM
GeeksGoneBad is on a distinguished road
There's the Joe's Hybrid 4X4 - but they're not free... were you looking for free?
there's also Solsylva.com I think that sells plans for larger sizes
Check out my projects at www.backyard-workshop.com
Old 06-25-2008, 10:02 AM
gfc62's Avatar
Platinum Member
gfc62 is on a distinguished road
Take a look at Joe's 4x4
When I was looking for a larger machine the best design I could find was Joe's 4x4. The plans aren't free but the cost includes access to an excellent support forum with contacts for parts suppliers and a great community of users willing to help you out.
Old 06-25-2008, 01:34 PM
I'm not looking for free, I would just like plans for a decent size system, and in a perfect world all the proper componets that compliment it.
I'll check out Joes plans.
Jeff
Old 06-27-2008, 03:01 PM
dmoore is on a distinguished road
Maybe a little more information will help get you going in the right direction:
  • Material you will be cutting
  • The maximum size item or description of items being cut
  • Hobby or commerical work
  • Acuracy
  • Budget
  • Space you have to work in (including materials storage, etc)
Old 06-27-2008, 06:14 PM
Material you will be cutting : Plywood, MDF, Acrylic, and maybe very thin aluminum
The maximum size item or description of items being cut : I would like to be able to cut up to 24-30" X 36-40"
Hobby or commerical work: Hobby, but more like a pro LOL
Acuracy: 9-10
Budget : Open
Space you have to work in (including materials storage, etc): Space is not really an option, I have about 600 sq. ft that is usable
Old 06-27-2008, 06:25 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Space & Budget Not a problem?! -- Why not move to 4x8 ft? "You build it...."
CadCut, MechMate are two good ones for that. (Or did I mis understand the comment on space -- but still thats only 32sqft out of your 600.
Jim
Welcome aboard! Hope you find some answers you can use.
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 06-27-2008, 07:59 PM
Talking
Well now, I can't say budget is not a concern. I'm just somewhat open in that area (if need be)
Space is much more easy to come by
Old 06-27-2008, 11:12 PM
As it's already been said, Joe's CNC Hybrid may be a good choice. You could go the mechmate - the real issue would be your fabrication skills. Joe's Hybrid is a garage bolt together - you can even purchase the HDPE and MDF parts already cut. Joe's forum (which I am a member of) is very good and helpful, you may find geralds mechmate forum a little more combative. Of course the plans for Joe's Hybrid is not free and the mechmate is. You can also build the mechmate in a 4x4 or 4x5 unit, though it's only a few hundred more to build a 4x8 or 5x10 unit. Joe's unit - 2500 to 3000 in 4x4, the mechmate in 4x4 is 4000 to 6000. Joe's unit will be something you built in your garage, mechmate will be something you look like you purchase (if you do it correctly). The mechmate will NOT have a problem with the aluminum, the joe's it's iffy. With the geared motors on the mechmate, the accuracy is very good, joe's less so. My prior shop was 600 sq/ft, so I'm pretty sure even a 4x8 or 5x10 would not be a problem (moving sheets around, storage).
It really seems to be an issue of the aluminum cutting ability and the overall cost. I think most people would say 4-6k is a bit high for hobby but that may not be your case.
Old 06-29-2008, 07:06 AM
dmoore,
Thanks for your input. I think I might have a little trouble with the Mechmate, since it seems to be fabricated out of metal. Joe's hybrid looks like a good 1st CNC choice.
As far as cutting aluminum, that's just on my wish list. No real need there.
Jeff
  #11   Ban this user!
Old 06-29-2008, 07:55 AM
LeeWay's Avatar
LeeWay is on a distinguished road
On cutting aluminum, you need to consider where all the flakes will go. I can cut aluminum and have done so. Sheet and plate as well as some 80/20 extrusions.
I only do this now when absolutely necessary. The router can suck in these flakes and it would just be a matter of time before a short occurs.
Not so bad if you have a decent dust collection hood. I find that I must drench the aluminum in WD40 though, so the stuff really sticks to everything, so the DC doesn't catch it all.
This was just a heads up, so you can plan for these issues.
Lee
  #12   Ban this user!
Old 06-29-2008, 06:59 PM
Leeway,
thanks for the heads-up. I'll try some WD40 if I ever get brave enough to cut aluminum.
I guess I need to start building something first.
Need some plans CMPM Open Source CNC Machine Designs 3 06-20-2008 12:39 AM
New Machine Build- Plans available? jeffInt Joes CNC Model 2006 1 03-03-2008 05:11 PM
DIY Plans... cnc-newb General Metal Working Machines 0 12-03-2007 08:41 PM
Plans nev25 CNC Wire Foam Cutter Machines 6 06-08-2007 03:12 PM
Newbie Help Hobbycnc Plans Krashlnd DIY-CNC Router Table Machines 8 10-28-2004 09:37 PM
