Old 06-20-2008, 08:35 PM
papagolf is on a distinguished road
New Build! need some thoughts!
This is my first build that I am creating from an old Helava photo negative scanner. it already had everything I needed for the X/Y axis' as far as rails and pillow blocks and a good foundation. The motor drives only had a movement of about 4 inches each direction. I fabricated a gantry from the aluminum plates they used to move the negative around with. I want to do a dual purpose machine for artwork so .001 tolerances are not really my concern. I will be using a rotozip or dremel for a routing spindle but my dad would like to do plasma. I have considered a belt type rack and pinion vs a dual acme lead screw for the X and the same for the Y but with a single acme. my travels are only in the 22" range so im not concerned about lead whip or anything just complexity of the design. Also in the case of a lead screw would you consider center drilling the lead screw and attaching directly to the motor? or would a bearing on each end with a motor coupler be in good design? and finally how would I determine the motor force required to move this thing?! thanks in advance!
Old 06-20-2008, 10:33 PM
johnmac's Avatar
johnmac is on a distinguished road
I'm not sure you need a dual lead screw for a 22" travel. I think it would be easier to build a sturdy table that doesn't "rack". If you can get good alignment, you could couple the screw directly, but the steppers are not designed for thrust loads.
John
Old 06-21-2008, 12:35 AM
John
The table is sturdy enough (60-70lbs of something - no flex at all)but the clearance in the linear bearings across the gantry will cause it to rack if driven from only one side. maybe tightening them up may help.... I thought dual lead screws may be over kill.... I was leaning toward mounting the X motor on the gantry and running a driven shaft across the gantry with a timing belt pulley on each end and doing it rack and pinion style. I'm just not sure if a 1/4"(its whats on hand) timing belt is up to the cutting forces of a small router if it hits a hard spot in the wood.
thanks for the thought on the steppers though... thats what I thought but I wasn't for sure!
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-08-2011 12:16 AM
thoughts on a model 425 Greg 24 Tree 2 04-25-2007 06:04 PM
CNC thoughts Tekko Benchtop Machines 6 02-12-2007 08:20 AM
BC.....Other thoughts dk1machine BobCad-Cam 1 07-06-2004 07:12 AM
