Old 09-12-2004, 07:56 AM
sixpence is on a distinguished road
speed issues
The machine I have managed to cobble together out of mdf(project log "She Lives") Has developed a death wish! It moves sooooo slowly. Probably due to a bad combo of electronics, motors software and me!
Help, what do I need to change to improve performance?
1. Master 5 ( motors set at max any more and they don't move the gantry)
2. lead screws :10tpi- 1/2" dia
x=800mm
y=500mm
z=300mm
3. Guide rails:thompson 1/2" diam +linear bearings for x+y
draw slides for z
4.motors: 12v .48A 1.8 deg
from rs components no:191 8340
5. drivers:built from scratch using L298 and L297 chips
from Geoff Williams book "build your own workshop bot(I don't want to do that again , ever) . Using 2 computer power supplies. 5v for the boards and 12v for the motors
6. Running pentium 3 computer.
Accuracy seems excellent but I can cut faster by hand!
Old 09-12-2004, 08:06 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Could be in the setup of the Master 5. I now that MACH2 has a few things that confused me when I was setting up and a similar result - different gear though.
I'm no electronics wizzard others could comment on that aspect.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 09-12-2004, 09:05 AM
arvidb is on a distinguished road
Originally Posted by sixpence
*snip*
*snip*
I'm quite sure the motor/power supply combo is your problem. What's your maximum step rate before the motors stalls?
If you power the windings with the motor's rated voltage, the rated current will flow through the winding, which will give full torque, which is great. This is when the motor is stalled.
But the motor windings have an electric property called inductance, which resists the flow of current; that is, it takes a short moment for the current to build up after you (or rather the driver board) apply the voltage. So as soon as you start to switch the windings (as when the motor starts to turn), because of inductance less current will flow. The faster the motor spins, the less current, which means less torque, and the motor misses steps or even stalls.
If you increase the voltage, the current will rise quicker, and so the motor will give more torque. But now the problem is that when the motor is stalled, too much current flows and the motor overheats.
The solution is to regulate current. Two ways are common: using series connected power resistors or transistors (very inefficient and the resistors are expensive and get very hot), or using a chopper drive.
The chopper drive is fed with many times the motor's rated voltage. It monitors current and when it is lower than optimum, it applies more voltage to make it rise faster. When the current is at the rated value for the motor, it regulates the voltage so that the current doesn't rise any more.
So you probably need different motors, different power supply, and/or different motor drivers.
Arvid
Old 09-12-2004, 10:10 AM
Graham S is on a distinguished road
The motor drivers are choppers (L298/L297) so an increase in drive voltage and preferably a decrease in motor voltage would probably do the trick.
Graham
Old 09-12-2004, 11:51 AM
ger21's Avatar
You ideally (at least on a low budget) want 2-3V motors and at least 24V power supply.
Old 09-12-2004, 04:23 PM
I didn't know the L297/L298 combination makes a chopper driver. I haven't looked much at steppers. Thanks for the info!
I just took a quick look in the L298's data sheet. Looks like it can take voltages up to 46V. Perhaps a good start would be to switch to a 36V power supply? Then if you are still not happy with the speed, upgrade the motors to lower voltage/higher current ones.
Arvid
Old 09-12-2004, 06:05 PM
You may find this site useful:
http://hans-w.com/cnc.htm
I made my drivers from his designs and they work well, he now has Eagle files for the PCBs as well.
Graham
You can see my boards at: www.indoor.flyer.co.uk/millingmachine.htm
Old 09-18-2004, 03:34 PM
thanks for all the info. I just happen to have 7v motors and a 24v power supply that I have to assemble. I'll see how that works. I used the 7 v motors with the 12v power supply and speed has improved but still slow. Next step the 24v power supply and loading windows xp so that I can install Mach 2. I have 3 seperate boards one for each motor.My electronics knowledge is verrry basic at best. How do I wire up the power supply to my boards? Do I just replace the 12v connections with the 24 v? Won't I fry the chips.I am trying to make myself believe that the only stupid Question is the one not asked.
Old 09-18-2004, 03:45 PM
circuit diag
hope this is clear
Old 09-18-2004, 03:50 PM
oops! try again, story of my life
  #11   Ban this user!
Old 09-18-2004, 09:28 PM
too small to see.
With my drivers you just use a different supply, yours should be the same. Check out the circuit on the above link and compare if you can't upload a bigger version of your schematic.
Graham
p.s. I am using 28v
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 08:01 PM
Speed how fast an axis can move? jlagran he General CNC (Mill and Lathe) Control Software (NC) 0 01-04-2005 11:05 PM
Spindle Speed & Feed Rates - Question Moondog DIY-CNC Router Table Machines 1 07-23-2004 07:24 PM
min speed exceeds max speed for axis "x"? ljoe1969 TurboCNC 4 01-19-2004 08:49 AM
AC Speed Control georgebarr General Electronics Discussion 7 01-06-2004 08:33 PM
