Old 06-19-2008, 09:01 AM
friklin is on a distinguished road
Limit switch Error
Hi there.
I just finished my first cnc mill. I run it an emc2 and ubuntu. The hardware is a 3axis set bought from Probotix. The problem I have is that I keep getting a limit switch error while running the cut. It seems to be random times and axis. I never come close to hitting any switches. Any ideas on what could be wrong.
Old 06-19-2008, 03:44 PM
Gir Gir is offline
Gir is on a distinguished road
There's either a lot of vibration causing chatter or a lot of noise in the line. Try using a shielded cable to run the limit switch.
Old 06-19-2008, 06:42 PM
Richster is on a distinguished road
Yes you either have a loose connection somewhere (assuming switch is normally closed) or you have noise in the system.
I had big problems with this. All my electrical lines are close together, so just activating the steppers was enough to trip the swithces, due to the electrical noise going into the parallel port. I know shielding can help in theory, but this didn't work for me.
I connected everything to the parallel port via opto-isolators in the end, which completely fixed the problem. There are probably other solutions too, but this one was relatively inexpensive and did the job for me.
Good luck - R
Old 06-19-2008, 06:46 PM
Karl_T's Avatar
Karl_T is on a distinguished road
If you want top shelf, move up to Opto isolation. This would be easy with used parts off eBay. Get opto22 input modules that use 5V logic and a board to mount them. Hook your computer inputs to the computer side of this board. Use a higher voltage on the other side of the opto inputs. 24 Volt DC is most common.
Karl
Old 06-21-2008, 05:26 AM
Limit switch error
Thanks I`ll try isolating the wiring first.
Old 06-21-2008, 06:09 AM
blackbeard52 is on a distinguished road
Karl
Take it a little easy on the newbies..... Could you give a diagram and maybe some part numbers for comparison as an example of your hookup. Most new machine builders dont know what a opto isolated anything is.
Bob
Old 06-22-2008, 04:51 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Wire your limit switches normally closed if you can, problem solved. Worked for me.
Old 06-24-2008, 05:56 PM
Cartierusm is on a distinguished road
Are you cutting wood or metal? I have some good cable but it's bunched together, but it's shielded. When I cut wood no problem, when I cut aluminum I have to turn the limits off because, I suspect, of noise.
Old 06-24-2008, 06:14 PM
Gir Gir is offline
Sounds more like a vibration issue. Wiring your switches normally open will fix chatter issues (unless you're getting some really bad vibes), and wiring your switches normally closed will help with noise issues (but might not completely fix them).
limit switch- home switch normd CamSoft Products 1 05-16-2008 07:56 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 08:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 01:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 06:58 PM
