Old 06-19-2008, 08:57 AM
jimmycakes's Avatar
jimmycakes is on a distinguished road
Our first machine is being cut out now.
I just sent out our files to my friend with a CNC. He's cutting out the pieces for the Lionclaw machine: LC50B.
I'll post some pictures when we start assembling.
It's being made from MDF and I guess there is a new waterproof MDF. Has anyone used the new stuff? Or has anyone tried painting their machine. I would be a little concerned about warping, but would like it to be slightly water resistant since it will be in my workshop in the basement. It's a little humid down there. But it's my only space. Thanks!
Old 06-19-2008, 10:16 AM
Khalid's Avatar
Khalid is on a distinguished road
Application of primer and paint will make it waterproof..I personally experimented with test piece of MDF and found satisfactory results..Just paint it all around don't leave a pin hole
Old 06-19-2008, 11:07 AM
jimmycakes's Avatar
Sounds good. I have a sprayer set up that should make short work of that. I suppose I should test fit everything first.
Old 06-19-2008, 11:18 AM
Khalid's Avatar
just check the joe thread... Prior to application of primer just give a coat of glue+40% water mixture...This will restrict the absorption and consumption of paint
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 04:54 PM
sell CNC Woodworking Machine,CNC Advertising Machine zhangrui1588 Product Announcements & Manufacturer News 0 05-30-2008 09:43 AM
machine gun noise on a haas machine serviceman Haas Mills 0 03-03-2008 12:17 PM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 10:37 PM
paper printer machine like cnc machine ??? patriciooholegu Mechanical Calculations/Engineering Design 3 08-07-2007 09:19 PM
