Old 09-11-2004, 09:18 AM
I'm getten there!
dmgdesigns is on a distinguished road
Actual load on Ball Screw?
How would I figure the actual load that is placed on a ball screw nut? Is this just the force to push an end mill through the material? Is the force to move the gantry on Thomson bearings while not cutting minimal?
And just how would one figure the force it takes to push say a 1/2 end mill through 3/4 Oak, MDF?
Inquiring minds want to know.
Mark
DMG Designs
League City, Texas
Old 09-11-2004, 09:31 AM
Al_The_Man's Avatar
You could use one of the motion engineering free software like http://www.motionvillage.com/motione...ine/index.html
If you go to the Kollmorgen site and click into the Motion Village site there is a wealth of info there.
Al
Old 09-11-2004, 10:12 AM
ger21's Avatar
I've read somewhere in the neighborhood of 30-40lbs should have you covered. Depends on bit diameter, flute geometry, tool sharpness, feed speeds, spindle speed......
Are you talking about cutting 3/4" oak in 1 pass?
MDF will cut a lot easier than the oak.
Sharp bits will cut with a lot less force required. Also, chipbreaker spirals cut much easier than standard spirals. They're not cheap, though.
http://www.vortextool.com/standard/p...fm?groupID=266
A bit like this will cut through oak like butter when it's sharp. And an added advantage is that it will cut much quieter, too.
Old 10-21-2004, 07:46 PM
senor J. is on a distinguished road
hey ger21 how long could you expect a bit like that to last?
Old 10-21-2004, 09:31 PM
ger21's Avatar
It depends. At work we cut mostly 3/4 plywood and partical board on a large commercial machine. You'll probably get a bit less life on a small, slow homebuilt machine.
To make it last as long as possible
Don't plunge straight down into the work, always ramp in.
Cut as fast as possible with the lowest possible spindle speed. Heat is VERY bad.
When you're cutting at high speeds, you can get better tool life out of larger parts, because if you have to start and stop alot like you would on small parts, you never really get to cut at the high speeds you'd like to, so tool life will suffer as well.
With a brand new bit, I probably cut 30 to 40 4x8 sheets worth of parts. This is usually at 300+ ipm and 16,000 rpm. With a 10HP router, I can use the bit a little longer because I have the power to push it through the work even when it starts getting pretty dull.
I also cut Maple and Oak up to the full depth of cut of the bit (~1-3/4"), in multiple passes. I usually try to use a new (or just resharpened) bit for hardwoods.
I usually get these resharpened 2 or 3 times, too. But it's not cheap (~$40, I think), and the more you sharpen them, the shorter the life.
I've also used them in handheld routers (with guide bushings) with great results. You wouldn't believe how much easier and faster they cut than a standard 2 flute straight bit.
And one last thing. Vortex gives large discounts on multiple bits. Sometimes on only 2 or 3 of the 1/2" bits, and you save about 30%. (kind of like buy 2 get one free). On 1/4" bits, the price break is around 7 bits. Just increase the number in your cart until you see the price break.
Oh yeah. If you think you can just get any carbide spiral bit and get the same results, you won't. I've used standard 2 flute spirals from Bosch and others, and compared to the Vortex bits, it's like night and day. If I need spiral bits, I'll never buy anything else. But I haven't tried Onsrud, and I hear they're quite good as well (and they have a HUGE selection http://www.onsrud.com )
Hope this helps.
Old 10-21-2004, 11:08 PM
hey, thanks a lot for your very informative answer. cheers
Jacob
Old 10-22-2004, 12:05 PM
*Registered*
ESjaavik is on a distinguished road
Hey, don't forget the force needed to accelerate the gantry! And even higher are those needed to accelerate the ball screw! The last one does not act upon your nuts, (ouchh if they did ) but better not forget it when choosing motors.
Cutting wood you want high speeds. High speeds means high acceleration. And the forces needed for that will probably dwarf your friction and cutter forces (in wood).
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Ball Screw Identification BeerFizz Benchtop Machines 2 04-07-2005 11:28 AM
Ball screw backlash options Stevie General Metal Working Machines 22 11-08-2004 12:32 PM
Need help with Ball Screw Choice samualt DIY-CNC Router Table Machines 5 09-06-2004 08:02 AM
Ball screw size/pitch? jakk100 DIY-CNC Router Table Machines 7 06-18-2003 11:21 AM
