  #13   Ban this user!
Old 06-13-2008, 01:43 PM
martinw is on a distinguished road
Dear erniebro,
It's probably worth having a similar type of arrangement where the lead screw passes through the moving gantry. For example, you could have a two leadnuts on the gantry spaced a few inches apart. The two could form an anti backlash system at the same time as keeping the screw in line.
BTW, I'm sure it's been done by loads of people..
Best wishes,
Martin
  #14   Ban this user!
Old 06-13-2008, 03:15 PM
One of Many is on a distinguished road
I'd think it would be less work to start over with a larger screw than design a fix to doctor a problem. I have found the fix itself comes with its own set of problems.
I had an opportunity to see a very, very larger Thermwood 5 axis router with a very similar screw support design that supported the 2"+ x 30-40'(?) high helix ball screws. The screws were stationary and the servos ran with the gantry turning the nut. The bottom of the gantry structure had a cam shape where the servos were mounted. The screw supports had cam followers that rode on the cam shape to handle a reversal in direction without interference. I get the sense this worked for this application for 2 reasons. First, the screw did not turn and second, there is far more flat surface on the high helix ballscrew than a standard threaded rod.
The problem you may gain is wear from a screw cutting into the support surface.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
  #15   Ban this user!
Old 06-13-2008, 10:46 PM
Khalid's Avatar
Khalid is on a distinguished road
erniebro thanks for explaining the concept..I am visualizing another idea..I will use C type half nut of teflon mounted with some retractable mechanism at the bottom of my Y-slide at a distance of 6" from my lead screw nut...As the fake nut arrived at the motor end plate it will automatically retract..as it goes back it will engage again...
Another idea is to mount the same in the middle of gantry, so when the nut mount plate come closer it retract and when it goes further it reengage...
Sorry for bad english
Ball vs. Anti Backlash Acme Screws eman5oh Polls 23 03-10-2012 08:33 PM
Long screws and rails 3Dsigns Linear and Rotary Motion 8 06-14-2007 01:59 PM
Akro Bins : long term storage solution? archimedes General Metalwork Discussion 1 05-10-2007 12:39 PM
Anti Backlash nuts to fit RF-45 screws Climatepro Benchtop Machines 4 04-14-2007 07:03 AM
How to support long lead screws....a solution spunky1974 Linear and Rotary Motion 0 11-07-2006 11:11 AM
