Old 06-10-2008, 10:35 PM
solodotcom is on a distinguished road
Pulling the pieces together
I have been gathering parts. My electronics are starting to trickle in and I'm needing to know what cable I will need to connect the breakout board to the computer? The breakout board looks like a parallel port. Do I connect to the parallel port or serial port on the computer? Thanks for all the great info here!
Old 06-10-2008, 11:03 PM
jalessi's Avatar
jalessi is on a distinguished road
parallel port
DB-25 Straight through cable
Jeff...
Old 06-11-2008, 06:57 AM
Thanks for a quick reply
I knew if I could ask the right question, someone here would give me the answer. Again many Thanks. I am now back to gathering parts!
Old 06-13-2008, 04:59 PM
Will Start Assembly This Weekend!
I know it's probably considered cheating, but I ordered the kit from BuildYourCnc.com. I'm more interested in what I can do with the finished machine that spending the time building it from scratch. That being said, I will try to take some pictures of the kit and the build as I go so I can share with folks on this forum. Again thanks for the info and support I've already learned soo much from you guys.
Steve
Old 06-22-2008, 09:53 AM
My Kit came in early last week
Here's a couple of pics of what I received
ID:	61920   Click image for larger version
Old 06-22-2008, 09:56 AM
Made some progress on assembley
Few Pics of what I've been able to get done so far.
ID:	61922   Click image for larger version
ID:	61923   Click image for larger version
ID:	61924   Click image for larger version
Old 07-08-2008, 11:10 AM
Router is in the Mounts!
Got the lead screws and anti backlash nuts installed on x and y axis. Went with a regular all thread for the z axis. Steppers are mounted and coupled. Build the stand and set the router in the mounts. Working feverishly on the electronics. I want to see this baby move! Couple of pics with the router. Should have some pics of the electronics tomorrow.
ID:	62779   Click image for larger version
pulling bar without barpuller pit202 Haas Lathes 3 06-02-2008 01:32 AM
203V Pulling my hair out!! WilliamD Gecko Drives 9 04-18-2008 02:09 AM
Pulling force meter Green Button General Metal Working Machines 1 09-26-2006 02:36 PM
Mazak QT-10 Bar Pulling jbhill Machine Problems, Solutions , Wireless DNC, serial port 2 08-09-2004 08:16 AM
Is Taig pulling my leg? c131fr Taig Mills & Lathes 27 07-12-2004 05:31 AM
