Old 06-10-2008, 09:44 AM
SPEEDRE is on a distinguished road
Tool Height Block Questions??
I need information about a tool set block. I have seen only one in operation. The one I'm speaking of is, a block of Alum. with a wire attached to it and set to ground point. When setting the Z axis the tool is joged to meet it, and when it does, the tool and the axis stops so that the tool is at the same height as all the rest. Is there a real simple way to make one or is it a buy only accessory??
Old 06-10-2008, 10:01 AM
solodex2151's Avatar
solodex2151 is on a distinguished road
You should be able to make one pretty easy if you can do some milling to get a flat surface and the desired height. The premise behind the block is that the block is grounded and you have a positive voltage hooked up to the bit. When the bit contacts the block, you get current flow and it acts like a limit switch. Works well for zeroing the Z-Axis.
Old 06-10-2008, 02:58 PM
Rance's Avatar
Rance is on a distinguished road
Its kinda rough but something similar to this Google SketchUp drawing?
Old 06-11-2008, 09:56 AM
Thanks Rance but I can not open that file. I do not support an skp file . Covert it to pdf if you can or dxf.
Old 06-11-2008, 11:32 AM
georgeburns is on a distinguished road
Another Aussie Auto Tool Zero Setter
Old 06-11-2008, 12:09 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Maybe you would be interested in something like this:
http://www.shars.com/products/view/1..._Z_Axis_Setter
CR.
Old 06-11-2008, 03:05 PM
Rance's Avatar
Speedre, you can get the viewer at http://sketchup.google.com/gsu6/download.html . You can also see it here http://tinypic.com/view.php?pic=acpgya&s=3 .
However, George's KISS solution seems MUCH better.
Rance
Old 06-12-2008, 09:12 AM
Thank You all. The information will be well used.
Old 06-12-2008, 06:39 PM
Greolt is on a distinguished road
In fact it needs to be the other way around.
The block or touch plate is connected to an input that is "high"
Then when it is grounded or touches the tool it brings the input low and signals the control software (Mach3 in my case)
Some setups may need a ground hooked to the tool via an alligator clip.
Others will have a good ground through the spindle and machine.
More info at this link,
Greg
BMC-10 tool change height leggetmachine HURCO 1 07-30-2007 10:45 PM
Setting tool height is300driver General Metalwork Discussion 12 11-14-2006 07:28 PM
Tool height logic Colin CamSoft Products 3 04-02-2006 04:11 PM
Setting Tool Height JAGYZF Commercial CNC Wood Routers 5 03-22-2005 08:22 AM
Tool Height Offsets JamesBond Machine Problems, Solutions , Wireless DNC, serial port 6 06-01-2003 03:01 PM
