Old 05-13-2003, 02:27 AM
georgebarr is on a distinguished road
noise from motor
I am trying to build my first CNC machine. I am concerned with the noise of the router motor. I am considering using an air spindle. I believe this spindle must use some sort of air compressor. Does anyone know if the air spindle with air compressor is quiter than a router motor? Where can I find air spindles and what are the price ranges for them.
I want to avoid having to build an outdoor shed just for my 4' x 3' cnc.
Thanks,
Old 05-13-2003, 09:14 AM
Laff Riot is on a distinguished road
http://pico-systems.com/Machining.html
Seems to be the guy to ask. He has one operating on a CNC machine he built. His pics of the spindle are under Projects - last selection.
Worry about success, failure takes care of itself.
Old 05-13-2003, 08:43 PM
balsaman's Avatar
balsaman is on a distinguished road
Air motors (die grinders) are just as loud as a router. They are not efficient. It takes a two horse power compressor to get 1/4 hp at the die grinder. Stick with a router.
Eric
I wish it wouldn't crash.
Motor Humming Noise? Dman Hobbycnc (Products) 12 11-09-2008 07:03 PM
Noise in Bridgeport 2J head (audio file included) daytrader Bridgeport and Hardinge Mills 4 11-15-2004 08:31 PM
Xylotex/TurboCNC/stepper motor set up problem buscht Xylotex 5 08-31-2004 09:16 AM
Which stepper motor should I buy Graham S FAQ of CNC Machine building 0 08-27-2004 06:58 AM
Servo's - oversupplying voltage for speed AJ_Mac2001 General Electronics Discussion 15 01-17-2004 11:32 PM
