How do I find out the best feed rate and spindle speeds for different router bits and materials? I know that too slow feed rate and too fast spindle speed cause "burning" of bit and material but what happens if the feed rate is too fast and the spindle speed is too slow? I checked the feed rate/spindle speed chart at http://www.amanatool.com/2008catalog..._feed_info.pdf but the slowest feed rate is 80 IPM and my CNC router's fastest feed rate is 20 IPM. My DeWalt trim router has spindle speed of 30,000 RPM and I thought that causes "burning" of bit and material. I ordered a router speed controller. |
You'll either stall the spindle or snap the bit. At 20 ipm, you don't have a lot of options. Your best bet is to use single flute tools, which gives the same effect as doubling the feedrate.
typically, I set a dinc (depth increment) value, per http://www.oretek.com/micromill/user.shtml of around 0.025 to 0.035 at a feed rate of about 40 IPM and acheive reasonable success with aluminum. It sounds like you're working on wood. I agree with the previous poster on this thread. You need a really sharp single flute router tool. For wood, I barely run the router to about 4000 RPM and hog out 0.1 to 0.25" at a time. I could likely hog out 0.5" with my current setup, but each system is unique in terms of load capacity. |
| On another note, I am not sure you are going to get the burning you are talking about. The bigger issue with running too slow a feedrate/too fast a spindle speed is that the cutter will wear out faster. Also, a secondary issue is more fine dust generated when cutting wood. For metals, check the machinery's handbook. Also, as Ger pointed out, some manufacturer's design bits with different feed specifications. Check out Onsrud for bits. |
| CNC feed rate and spindle speed | misc.garfield | General CNC (Mill and Lathe) Control Software (NC) | 5 | 01-29-2008 05:20 PM |
| Feed Rate and Spindle Rate for this cut? | DroopyPawn | General Metalwork Discussion | 20 | 11-21-2007 11:12 PM |
| Feed rate and Speedle speed for M4-.7 tap | chakaloso | Haas Mills | 9 | 09-20-2007 03:52 PM |
| surface speed and feed rate calculator | derkiow | General Metalwork Discussion | 9 | 06-04-2006 07:33 PM |
| Spindle speed & feed rate on a Taig | Stuff-Builder | Taig Mills & Lathes | 5 | 08-29-2005 05:01 PM |
