I replaced the 5/16-18 threaded rods with 3/8-12 ACME leadscrews and cables with 22-gauge wires with cables with 18-gauge wires and quick disconnect connectors on my 17X20 Overhead Leadscrew CNC router and found that I get 20 IPM instead of 10 IPM. I will try using my CNC router next week. |
| I used my CNC router to make two signs and the machine worked faster than before thanks to new 3/8-12 ACME leadscrews and I set the router speed controller at 5 (half-speed) and there's no "burning" of bit and wood. I'm not sure about solid carbide router bits made by Amana Tool. The 3/16" CNC Spiral Flute Plunge Solid Carbide bit didn't left smooth cuts and I had to sand the letters. The bottom of the bit isn't flat. Any suggestions? |
| These Freud Bits have worked beautifully for me before. |
The bottom doesn't need to be flat to leave flat bottom cuts. Any flexing or vibration anywhere in your machine can lead to poor cut quality. And the spindle needs to be perfectly perpendicular to the table in all directions as well.
| My CNC router blew two 2.5A fuses while trying to rout two signs today. I bought some 3A fuses while coming home. Any reasons for my CNC router blowing fuses? It has Probotix PBX-RF board, three ProtoStep boards, and three 200OzIn unipolar stepper motors. |
| What are the specs on your power supply, the impedance/draw of your motors, etc? |
the probostep boards push 3 amps. Probably the 2.5 amp fuses. |
| Power Supply: 24Volt 4.3Amp Switching Power Supply 100-240VAC 50-60Hz Stepper Motors: http://www.probotix.com/specs/HT23-200-6_specs.jpg 2.5A fast-blow fuses already used. Bought 3A fast-blow fuses but not yet used. |
| Replaced encoder, replaced cable, still can't get 4th axis working | ralph@nes | Haas Mills | 40 | 02-07-2008 05:03 PM |
| ACME Threaded Rod | JohnG | DIY-CNC Router Table Machines | 4 | 05-19-2006 01:32 PM |
| Acme leadscrew or Trapezoid leadscrew is better? | minicnc | DIY-CNC Router Table Machines | 3 | 03-07-2005 11:57 AM |
| What Acme threaded rod to get? | CNC Darren | DIY-CNC Router Table Machines | 7 | 09-29-2004 06:14 AM |
| Acme threaded rod use | Apples | DIY-CNC Router Table Machines | 6 | 05-12-2004 12:54 AM |
