Old 05-29-2008, 02:48 PM
tvdbon is on a distinguished road
Cool Mini PCB drill table
OK, so this will be my build thread for a new mini table. I want to make a small cnc that I can use to drill the holes on my pcb's. At the moment I'm planning at able as small as needed for me to drill holes into a 160mmx100mm pcb board (eurocard). I'm planning on using mdf for the structure and a dremel for the router part. Normal m6 threaded screws for driving it and 3 30 oz stepper motors.
Does anybody see any problems with what I want to do so far ?
Old 05-29-2008, 04:32 PM
jemmyell is on a distinguished road
don't use a dremel
If you want to drill small holes then the dremel will typically have WAY too much runout. Either use a Kress 900 watt router or get one of the nifty spindles from Wolfgang Engineering that are sold on eBay. I just bought one of those and I am waiting for delivery now.
-James
James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
What's the best way to drill deep holes on a 7x12 mini-lathe? digits Mini Lathe 8 01-25-2008 09:12 AM
I need help choosing a mini electrical drill. Calvi General Metal Working Machines 6 02-23-2007 05:05 AM
mill drill table ron mcbee Mechanical Calculations/Engineering Design 4 11-18-2006 05:47 PM
Table drill in a Mill villas Mechanical Calculations/Engineering Design 12 09-12-2006 10:22 PM
CNC Drill driving the milling table Com Vertical Mill, Lathe Project Log 2 04-04-2005 03:27 PM
