Hi There, I've got a rockcliff machine up and running and done some basic stuff. I'm currently in the process of putting on some limit/home switches, but one thing that I've always wondered is whether the 0 point of the z-axis should be on the table or on the workpiece ? So far I always had the 0 point on the workpiece and then I modifed my g-code to travel the z axis into the minus. Example if I wanted to make a 1mm cut deep then I would tell it to go to Z-1.0000 Is this the right way? How does it usually work on cnc machines ? |
Yes. that's the right way. 0 is the top of the workpiece. What are you creating your code with that you need to modify it? Pretty much all CAM programs write code with Z- moving down into the work, although most will give you the option to do it differently.
| So far I have only used lazycam. But I'm still learning it so I haven't done more than load a picture, post the gcode, modify z and then cut it. Nothing great yet, but I'm still learning. So I guess the best would be to have my z-axis home in at the highest possible z value. Thanks guys, thats what I suspected but I wanted to check with experts first |
| Busellato Optima Point To point | Malacara | General CNC (Mill and Lathe) Control Software (NC) | 0 | 12-11-2007 06:22 PM |
| Z Axis Starting Point in DCAD Execute/Simulation | jim_stoll | Dolphin CADCAM | 1 | 09-16-2007 02:08 AM |
| converting point to point programs | kevinwd1 | General CAM Discussion | 2 | 06-11-2007 11:45 AM |
| Home, zero, starting point... | saturnnights | General CNC (Mill and Lathe) Control Software (NC) | 4 | 02-14-2006 02:57 PM |
| Z axis Home backoff | Stevie | Mach Mill | 1 | 12-20-2005 05:28 PM |
