Oops, that title doesn't sound quite right, does it?
I recently began researching what it would take to build my own CNC router/plasma table and was very fortunate to stumble upon this website. I have absolutely no experience in this field - I come from the civil engineering and construction side of things. However, for the past several years, my son and I have gotten into restoration of classic muscle cars. I currently make specialized parts one at a time using hand and power tools found in your typical home shop - nothing fancy. What I hope to do is build a small (3'x3' or so) CNC router or plasma table to automate the process. The problem I face is not knowing which one would be best suited for my purposes.
Here is what I would like to ask you folks (yes, the title of my post is a play on words). Would one of you who has a router table and one of you who has a plasma table be willing to cut a small bracket for me, so that I can compare their quality and finish to help me make up my mind which direction I should pursue? The bracket is cut from thin aluminum sheet stock (think... street sign), and it is roughly 11"x5" with a couple of drilled 1/8" mounting holes and two other 3" holes in the center. I can provide a photo if necessary.
I can send you a blank stock of material (it fits nicely in a letter-size manilla clasp mailing envelope), and I can provide an AutoCAD file (dxf I presume). I will provide a separate pre-paid mailing envelope, so the only thing you will be out-of-pocket is a little bit of your time.
If you are willing to help me with this, please send an email to me so we can work out the details. I would greatly appreciate any help you can provide. I have seen so many nice do-it-yourself projects on this site, and I can't wait to have my own table. I just want to make sure that what I invest my time and money on will be something I can live with for quite a while. And I certainly don't want to put more into the project than what is necessary.
I look forward to hearing from some of you,
Jerry
jnlandes@sbcglobal.net
