Moving table design: I am using 1/5" 8020 extrusion and 25mm rails and, to my suprise, I am getting about 20-25 mil deflection in the center on 24" long rails. Just an FYI for any other DIY cnc'ers...dont assume. ![]() Its my own fault, I should have done the math than assumed it was already over-engineered. The spans are not sitting on the ground, they are suspended 1/4 inches off the ground by the plates on each end. This 1/4" spacing was meant for the base plate, but I haven't found the right size cheaply yet...but I guess its more priority now! |
| I think the next moving table gantry design I do will have a granite surface plate for the base. IMO you lose the gains from a fixed gantry/moving table if your moving table is mounted to a flimsy surface. Now to figure out if I can mill/drill holes in a ENCO granite surface plate with my 60 watt CO2 laser. |
| I am definately going to get that base plate on there. I am thinking .375 to .5" plate. I am going to do the math this time though. How is that co2 laser working out for you? I would like to have a friend make me one soon. What kind of materials have you cut and thicknesses? Do you use a gas at the cutting point to enhance cutting power? Did you buy or DIY laser? Obviously, you have my interest now! ![]() Colin |
| Base plates | xcranker | Work Fixtures and Hold-Down Solutions | 3 | 12-26-2010 11:13 PM |
| Keeping the cutting bed from bowing? | matt888 | JGRO Router Table Design | 15 | 01-07-2008 03:11 PM |
| 15M ram Parity (base 0) | Stu00 | Fanuc | 2 | 10-29-2007 09:49 AM |
| Base advice | Graham S | DIY-CNC Router Table Machines | 4 | 08-25-2004 03:09 AM |
