Old 05-22-2008, 09:19 AM
skipper_52 is on a distinguished road
Lathe code idea for Z
I got the lathe attachment done for the machine and it performs well with the exception of the motor being a little underpowered. I wondering if anyone has done this yet. I was struggling with drawing the clock arbors and the Z code generation. If the stepover settings for tools is the same thing as the stepdown for Z then you should be able to swap the Z cable for the Y and trick the machine so there would be no need to find & replace code with notepad. Always appreciate the feedback here.
Old 05-22-2008, 06:28 PM
Regnar's Avatar
Regnar is on a distinguished road
Rather than switching out cables each time why not just make two different profiles. One for milling and one for lathe. Then all you would have to do is switch the pins and direction once and open the profile for the different operations.
CNC Lathe G code G73 / G83 nelsonrb4 G-Code Programing 7 12-30-2011 05:50 PM
CRAZY LATHE IDEA KENNETH BROWN General Metal Working Machines 13 11-23-2007 05:29 PM
cam to g-code for cnc lathe slow_rider General CNC (Mill and Lathe) Control Software (NC) 0 10-21-2006 01:16 PM
CNC Lathe Threading G-Code HELP>>>> vtech99 Coding 2 08-26-2006 03:30 AM
fanuc 11 lathe g-code bobcor Fanuc 3 08-20-2006 02:16 PM
