| Hi I am looking into everything I need for my design for my engraver/mill I was woundering is it worth just buying the lead screws or making them on a lathe? if making is there any info here? or buying whats best on this? sorry for all the questions Thank you Karl |
| Hi, I almost have the same question, should I use a stainless M12 bar or ACME/Trapetzoid 12/3mm bar. What is the main advantage using a ACME type, my intention is to make a AB nut from Delrin just because I don't have a tap for ACME, but a lot of Delrin and metric 12mm taps, plastic or metal ACME nuts are a bit hard to find and if they are expensive. I can understand that the metric 12mm bar need a faster stepper motor speed if I want to make a lot of products. Can it be a precision problem with the 12mm metric bar or just the speed problem. Kind regards Signit |
| I started out with M12 threaded rod on my CNC Router, there is nothing wrong with them just that they need a fast stepper motor, whip can also be a problem.I had a major whip problem with them in my machine so I switched to 12mm x 3mm acme leadscrew, they really made a big difference the rapid feed speeds doubled.Its easy to make a acme tap just take a offcut piece of acme rod grind or turn a taper on it and then grind some nice big slots along its length, thats what I done it works very well to tap delrin. |
thanksIs there anywhere that I could get 12mm x 3mm acme leadscrew cheap? |
| Marchant Dice sell TR12x3 acme screw in the UK, I think they are your best bet, they have a new online shop www.worldofcnc.com they call the acme leadscrew trapezoidal spindle they also sell the matching leadscrew nuts. |
![]() What would the best thread size be to get a good fast speed? |
| TR12x3 seems to be the most popular choice for good allround performance and cost.I get 2400mm/min or 40mm/sec rapid feed speeds on my machine which is more than enough for my purposes using TR12x3 trapezoidal spindle.My longest leadscrew measures 1700mm and has a little whipeso maybe the TR16x4 units would be a better choice depending on your max leadscrew length. Hope that helps |
![]() thank you for your time |
#10
| Also it would depend on what moters you are using I think, I am still working alot out by just reading threads on people that have done theres and got a nice set up at the end. |
#11
| First I dont think you could make your drive screw unless you have a cnc lathe. ok try www.roton.com they have all typs of screws, if you need speed go for 1/2 inch 8 tpi with 4 starts. if speed is not needed just go with standard acme that you can get any were. You dont need a super big stepper to get speed, the a good driver helps but the screw with less threads per inch and higher starts will get you more speed with less whip. good luck. Graham |
| lead screws | Runner4404spd | General Metal Working Machines | 4 | 02-07-2008 08:36 PM |
| Where to buy lead screws? | eldruida | Linear and Rotary Motion | 1 | 09-24-2007 06:33 AM |
| 1 or 2 lead screws | spoolin_20b | DIY-CNC Router Table Machines | 6 | 03-22-2007 04:50 PM |
| How to support Lead screws | Hacksaw | Mechanical Calculations/Engineering Design | 19 | 01-24-2007 06:52 PM |
| Lead Screws | mdframe | DIY-CNC Router Table Machines | 14 | 03-21-2004 08:20 PM |
