Old 08-30-2004, 02:40 PM
signIT is on a distinguished road
The Zoltar CNC Router
My Zoltar is ready for work, the first job was for a friend, two brass plates 1mm thick medium hard.
A very nice and neat machine with high capability, from wood to soft metal like aluminium and brass.
My next project is a stepped attenuator with 24 positions.
Here is a picture of a working Zoltar this machine is equipped with three 0,8A steppers and Conrad EMIS SMC1500 driver and PCNC_SMC software.
This is the EMIS web site http://www.emisgmbh.de/smc1500.htm
Leffe
ID:	3307   Click image for larger version
Old 08-30-2004, 03:46 PM
InventIt is on a distinguished road
Nice looking machine.
Where did U find those nice wire connectors in the lower right of the photo?
Old 08-30-2004, 04:05 PM
Connectors
They are from Neutrik this a 5 pole type I think they have 6 poles or more.
I have connected them by axiz letter X Y Z, and the rest poles is for end switches, I use common ground for the switches and only four cables from each motor so I only need this three connectors.
BTW here is the URL http://www.rcmodels.net/cnc/ to the Zoltar designer Chris Reinder he only sells the plans and maybe some small parts I think this is the most economic way to learn and use CNC technology, common handheld tools can be used no need for expensive tools or machine shop.
Leffe
Old 09-02-2004, 01:41 PM
Products
I have a small production of a 24 stepped volume control meant for HiFi.
The Zoltar is loaded with a carbide router bit I found a set of 50 different kind of router bits just USD35.
ID:	3318   Click image for larger version
ID:	3319   Click image for larger version
Old 09-03-2004, 01:06 AM
New steppers
I have tried to get more power to X and Y axiz I have some small steppers 2A and 0,8A I have changed to the 2A steppers but it doesn't get more power to the axiz why? is it other parameters that are more important than current, should I buy longer steppers with same flange size, I have seen a nema 23 size with almost same current 1,4A and 1,5A the 1,4A is a short one and the 1,5 is a long I am confused.
If I have to stay with NEMA23 size what kind of stepper should I choose.
Leffe
Old 09-07-2004, 02:44 AM
Finish Line
Hi all chip sweepers,
I found that this product, Finish Line, can solve the problem with trapetzoid screw I increased the speed 5 times with this product meant for bicycles it contains teflon very nice to use.
If the trapetzoid screw is made of steel and the nut is made of brass don't use WD40 it is to thin and it may help to carve into the nut use it as carving oil when you makes threads.
Leffe
This is the site of The Zoltar CNC Router they have many links to great products for people that will build routers http://www.rcmodels.net/cnc/
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 11:12 PM
2nd Generation CNC Router Design 32.5” X 14” X 6” gregmary DIY-CNC Router Table Machines 9 03-24-2005 05:46 PM
Zoltar CNC Router signIT DIY-CNC Router Table Machines 11 04-17-2004 11:25 AM
buscht's cnc router buscht DIY-CNC Router Table Machines 25 04-13-2004 12:43 PM
My first CNC router: 1.5 years building hddjohns DIY-CNC Router Table Machines 2 04-03-2004 11:18 AM
