Old 05-16-2008, 12:36 AM
Hydrodynamic is on a distinguished road
Allen Bradley AC Servo Motors
CAT NO. MPL-A430P-HJ22AA
5000 Max RPM
16.8 Peak Amps
230V 3Phase
0-333 HZ
I want to build a 2 axis table for plasma or router using these motors, along with these motors are matching 10:1 reducers. What type of controller would I use? I have some understanding as I have worked on an ESAB waterjet. The mechanical side I can figure out, but the electrical from the computer to the drives has got me lost. I am familiar with bobcad for programing if that matters.
Old 05-16-2008, 10:00 AM
KTP KTP is offline
Gold Member
KTP is on a distinguished road
I think the data sheet and installation instructions for that motor are here:
http://literature.rockwellautomation...n001_-en-p.pdf
Nice motor, 2000 line encoder, halls, and 2.2 killowatt output. You will need a beefy brushless servo amplifier to drive it. I suggest looking into the Granite devices amp. There is a sub-forum on here about it.
Clueless in Indy- questions about Allen Bradley servo setup snapman Servo Motors and Drives 20 02-15-2007 10:14 AM
Allen Bradley servo motor cables 69owb Servo Motors and Drives 0 01-31-2007 05:06 PM
Servo drive Allen Bradley efrem Mach Software (ArtSoft software) 13 10-28-2006 02:09 PM
Allen Bradley servo drive efrem Servo Motors and Drives 4 07-05-2006 10:07 PM
Allen Bradley Servo spec help CAM_MAN Servo Motors and Drives 1 02-23-2005 11:00 PM
