08-31-2004, 03:59 PM
 | Moderator | | Join Date: Jan 2004 Location: United States Age: 33
Originally Posted by andyew
Btw, suddenly i have another idea for the linear motion, i might use square steel solid rod (instead of stainless steel round pipe) AND skate bearings mounted perpendicular to each other on L-bracket (********** design). I think it's better than using ROUND rod/pipe because the bearing will roll across over wider "contact surface" and thus less pressure (force/area). This will reduce the wear on the rails (solide steel square rod in this case).... |
I think most people here will tell you that using square tubing for bearing rail is dis-advantagous. It allows for contaminate buildup which could fill up and stop your bearings.
__________________ Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5% |
