| I think radioshack has some Molex, here's where I got mine though: https://www.alliedelec.com/images/pr...irtualcatalog/ Page 201 for the index of connectors, page 217-219 for Molex type. - Andy |
| Well unfortunately you'll always have to solder the wires onto your cable connector (hopefully that's not what you're trying to avoid :\ ). If you have any old computers laying around, scavenge some molex connectors from them. Most computers will have anywhere form 4-8 usually (maybe more). That's what I'm doing. |
| I have computer cables with 9-pin "D" connectors but I may not have enough male and female connectors. I'm not sure if cables made by different companies have same color wires. I think that there's two kinds of molex connectors. The ones that connect to disk drives are usually large white connectors with 4 pins and the ones that connect to motherboards are smaller female connectors and I don't think that there's male connectors. The stepper motors require five wires to work. Two of the wires coming from the stepper motors are connected together before being connected to the driver boards made by Probotix. |
| I use 5 pin Molex connectors, they look just like the hard drive connectors but have 1 more pin. They are crimp connectors, but I never trust a crimp and always solder them. I have 4 wire steppers, and use the 5th pin for the braided ground shield on the cable, it ties back to chassis ground in the control box. We have several sets of different high-precision linear stages here at work, one of them is about 3' x 3', and has rather large stepper motors on it. They are using standard 9-pin serial port type connectors, and this is probably a $10,000 linear stage with some pretty good size steppers. So apparently just about any connector will work. The cables *look* like standard serial cables as well, but I don't know if the wires are larger inside or not.. |
| Here are some plastic cannon plugs. Its the same thing the military uses on aircraft just plastic. I know they make water tight connections to but I didnt seem them. The pins and sockets can be solder or crimp. What is nice about these connections is that they can only go together one way and then they are threaded on, so pretty much accident proof. http://www.mouser.com/catalog/634/1240.pdf |
#11
#12
| Gir is right the nasa stuff is way out of our league. A military/nasa cannon plug goes for around 200.00 and the tooling goes up from there. The ones I showed you are around 8 dollars for 1 whole connection. The only tools I used was a pair of needle nose pliers and a stir stick from McDonalds |
| y axis disconnect alarm | kirby | Fanuc | 8 | 03-14-2008 04:27 PM |
| Need disconnect for powerfeed | Chevy-SS | Benchtop Machines | 2 | 04-09-2007 10:27 AM |
| Best type of quick connectors for motors? | pfarber | General Electronics Discussion | 31 | 01-04-2007 04:43 PM |
| how do I disconnect microswitch? | jeremyinnys | General Electronics Discussion | 3 | 10-12-2005 10:40 AM |
| Cable Connectors | redbaron | DIY-CNC Router Table Machines | 4 | 01-27-2004 12:56 AM |
