Old 05-14-2008, 12:11 AM
nicanor76 is on a distinguished road
parallel cable pins
I just got a $2 parallel cable from the thrift store, I've never tested a cable before so am not too sure. All the pins (on the PC side) all tested to be active, but they all don't go chronologically connected on the other end. Most of the top pins are all in order in the other end though. And not all of the flat contact connections (on the printer side) are active, since there's more connections on that end vs the other end.
So I'm guessing as long as all the connections (on the PC side w/pins) are all active I should be ok, right?
Old 05-14-2008, 05:16 AM
randyf1965 is on a distinguished road
I think the cable you are looking for is a 25 pin connector serial cable
Old 05-14-2008, 05:41 AM
blackbeard52 is on a distinguished road
Yes it is and make sure they are the same pin configuration on bot sides....parallel instead of null modem.
bob
Old 05-14-2008, 06:06 AM
jalessi's Avatar
jalessi is on a distinguished road
Do not connect a cable that is not wired straight thru to a Parallel Port Device
Most External Parallel Port Devices use Straight-Through Parallel Port Cable with Straight pinouts like 1 to 1, 2 to 2, 3 to 3 and so on up to 25 to 25.
A Straight-Thru Cable is required for BOB Interface and Stepper Drives such as Hobby CNC, Xylotex etc...
If the cable you have has a db-25 on each end and is not wired straight thru in fact could either be a serial cable or a Parallel Port Null Cable
" Laplink Data Transfer Cable"
Do not attempt to connect a cable that is not wired straight thru to a Parallel Port Device.
Old 05-14-2008, 11:20 AM
ah ok, I jumped the gun. My drive components in the mail so haven't seen the connections yet and assumed it's a standard printer connection. I'll go back to the thrift store and try find one. But this is what I'll need, right?
Also I'm assuming I shouldn't go too long. Is 25' too long? Will prefer a 15' or shorter but these cables are slim pickings sometimes. ... Thanks again
Old 05-14-2008, 12:24 PM
jalessi's Avatar
nicanor76
A 25 foot cable is pushing the limits of a Parallel Port.
See the attached link for a ten foot cable.
http://tinyurl.com/47xz92
Jeff...
Old 05-14-2008, 04:38 PM
Thanks. I searched through eBay but living in Canada, most of the sellers won't ship to me. I found one locally (NCIX.com) for $6ish in case anyone in Canada is looking for one. Posting link here in case for future reference. Will order one soon, test out all the pins, and share the results.
3' cable:
http://www.ncix.com/products/index.p...facture=BELKIN
10' cable:
Old 05-14-2008, 05:01 PM
jalessi's Avatar
Belkin makes top shelf products, you wont go wrong buying Belkin!
Old 05-14-2008, 06:01 PM
I would wait for the drive first... Sometimes manufacturers put male and sometimes they use female connectors on thier cards. for sure you need a male connector for the computer.
anyone tried USB to Parallel cable? nicanor76 DIY-CNC Router Table Machines 5 05-11-2008 07:09 PM
Popup pins Adam M. Work Fixtures and Hold-Down Solutions 0 01-15-2008 08:43 PM
Parallel Cable Length Cartierusm Mach Software (ArtSoft software) 2 09-11-2007 11:53 PM
Configuration Of Output Pins In Parallel Port FOR 4 AXIS Khalid Open Source Controller Boards 2 05-20-2007 01:55 AM
Are all Parallel Extention Cable Straight Through? Mr.Chips General Electronics Discussion 2 01-18-2007 07:56 PM
