Old 08-27-2004, 05:19 PM
chozo is on a distinguished road
Timing belts.....what type do you use?
I might go with a pulley system for my gantry, and I was looking into timing belts.
What is a good tension to use? Should you use a tool to measure it, or can you just feel if it's right?
Thanks!
Old 08-27-2004, 06:39 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
I do the feels about right method.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-27-2004, 08:52 PM
sendkeys is on a distinguished road
ya im also going to be looking for some belts here soon.
What type of belt is best when dealing with eliminating backlash?
looking at sdp-si. would kevlar be the best? also would urethane or polyurethane be better?
Old 08-27-2004, 10:01 PM
ger21's Avatar
The tooth profile has a lot more to do with backlash than the belt material. SDP-SI has a lot of good technical info on belts, and will send you free catalogs as well. According to their documentation, the GT2 belts have the least amount of backlash.
http://www.sdp-si.com
Old 08-27-2004, 10:19 PM
ahh hunting around there help stuff found a nice pdf i get to read all about it thanks ger21
Planetary gearhead vs timing belts Swede General Metal Working Machines 4 03-27-2005 09:19 PM
Timing belts for x and y axes (what pitch?) dowling177 Mechanical Calculations/Engineering Design 2 01-27-2005 10:12 AM
Timing Belts chas DIY-CNC Router Table Machines 1 01-19-2005 10:03 AM
Cheap Source for Timing Belts and Pulleys? samualt DIY-CNC Router Table Machines 10 09-10-2004 07:41 AM
Timing belts, gears, and ratios samualt DIY-CNC Router Table Machines 11 12-19-2003 08:09 PM
