Old 05-09-2008, 12:20 PM
nicanor76 is on a distinguished road
anyone tried USB to Parallel cable?
The laptop I want to use doesn't have a parallel port, as most new PCs neither. Has anyone here tried a USB to 1284 cable to connect to their controller box?
Old 05-09-2008, 12:35 PM
ger21's Avatar
Won't work with software that sends step and direction signals to the parallel port. You're best bet , if using Mach3, is the Smoothstepper, which will give you two parallel ports from a USB connection. www.warp9td.com
Old 05-09-2008, 12:57 PM
So the software itself can't change the output source, always goes to LTP1? Interesting. How about using a PCMCIA card?
Old 05-09-2008, 01:12 PM
Dennis Bohlke's Avatar
Dennis Bohlke is on a distinguished road
I tried to use them and found them impossible to get more than a few hundred steps per second out with any fidelity.
The problem stems from a one(1) millisecond latency on the USB data channel. That is it can take up to .001 second for the data to be presented to the pins of the parallel port after the processor command to do so is executed.
Dennis
http://www.super-tech.com
Old 05-11-2008, 03:11 PM
How about the PCMCIA cards for laptops, anyone uses them with success? They're a lot more reliable than USB adapters
Old 05-11-2008, 07:09 PM
ger21's Avatar
Some have used them, and some have had trouble. They should work, but there's no guarantee.
Parallel Cable Length Cartierusm Mach Software (ArtSoft software) 2 09-11-2007 11:53 PM
Stepper Cable dneisler General Electronics Discussion 1 07-01-2007 08:43 PM
cable lgalla Stepper Motors and Drives 7 02-10-2007 09:55 AM
Are all Parallel Extention Cable Straight Through? Mr.Chips General Electronics Discussion 2 01-18-2007 07:56 PM
Heidenhain Cable watzmann CNCzone Club House 2 06-30-2006 07:02 AM
