http://www.cncrouterparts.com/parts.html What is the point of the needle thrust bearings and washers (parts 3 and 4) in the linked design above? Maybe I'm tired... but I can't figure out their purpose... seems to me they will just sit on the screw shaft without any function. Thanks... gb |
| They take the thrust. ![]() Regular ball races are not designed for axial loads so the thrust from the screw has to be taken with thrust bearings. This type of construction gives some backlash because things cannot be cinched up with zero clearance using thrust bearings like this. On a more expensive setup ball races designed for taking axial loads would be used, two of them back to back preloaded to take out an freeplay.
| As an added thought, one could use a belleville spring or wave washer to preload the needle brg setup. This takes out the endplay up to the spring load force. Likely a better solution as mentioned above would be either tapered rollers or angular contact bearings with a suitable preload. JC |
| Sorry for being dense, but what axial thrust? Isn't this part simply holding the screw in place? The surfaces these thrust washers are up against don't move, right? Like the orignial poster, I don't see their function. Where is the axial load comming from? PS, the non-exploded view of this particular assembly can be found here assembled view |
| I guess I always assumed that the screw was free to slip axially on the skate bearing and so any back force would be transmitted directly to the coupler/motor/motor mounts. However, thinking about it what you said makes perfect sense. Thanks Geof. |
| And the screw must be held very firmly in place. Any movement (backlash) will show up in your cuts.
| Small Needle bearings..... | IN-WondeR | Mechanical Calculations/Engineering Design | 0 | 01-24-2008 04:56 PM |
| Needle Bearings and Dowel Pins | Alex Westling | Mechanical Calculations/Engineering Design | 2 | 01-18-2008 11:34 PM |
| Whats the best oil for linear bearings ? | Brenck | General Metal Working Machines | 2 | 03-05-2007 03:47 PM |
| Brass needle valves | mrwhittle | General Material Machining Solutions | 15 | 11-07-2006 06:07 AM |
| Needle thrust bearings | cncuser1 | Mechanical Calculations/Engineering Design | 6 | 09-18-2006 06:13 AM |
