Old 04-29-2008, 03:26 PM
Mini-MillX2 is on a distinguished road
Surfacing Bits...
What bit should be used to surface a table once it's built? The spoilboard surface is 3/4 MDF on a 4'x8' table with a Porter Cable 3 1/4hp router. I wasn't sure using a fly cutter in a router was safe or if some other tool should be used/intended for this purpose. I tried to search but didn't find any information on what bits others were using. Thanks.
Old 04-29-2008, 07:57 PM
ger21's Avatar
If you don't want to spend $300 on a spoilboard surfacing bit, just use the biggest straight bit you can find.
http://www.vortextool.com/standard/p...fm?groupID=305
Surfacing question frunple BobCad-Cam 16 07-11-2009 08:22 PM
Surfacing SyilAmerica Syil Products 2 12-17-2007 11:38 AM
smooth 3d surfacing? Rich05 Mastercam 22 10-23-2007 10:43 AM
4 axis surfacing ?!? Janos Mastercam 4 08-15-2007 08:04 AM
surfacing help lt paul Rhino 3D 2 07-16-2004 09:48 AM
