Old 08-21-2004, 08:36 AM
Moondog is on a distinguished road
Bearing Block Question
Hope you can help.
Just designing my Drive bearing Block for my Y Axis. The block will be made from 30mm Aluminium and will house a double Angular contact bearing.
To bolt the block to the gantry is it better to use 4-8mm bolts or 2 -12mm bolts. See my attached DXF. The lead screw will be 1600mm thread.
thanks
Name:	Y Axis Drive bearing block.jpg‎
Old 08-21-2004, 11:13 AM
HuFlungDung's Avatar
Moderator
It's your choice really. I would tend to prefer the face mount bolt pattern, because it seems like the easiest method to get the bolts drilled in the correct place in the frame, using an existing hole as a reference. If you use bolts in the shoulders of the block, then you've got to worry about the squareness of that bolt face relative to the screw axis, as well as the troublesome shimming of the pillow block in any attempt to readjust the natural centered position.
Old 08-21-2004, 05:17 PM
Thanks HuFlung
Sorry...I probably didn't explain myself too well in my post.
My only choice is bolting thru the shoulder, ie, from the top...
However, when Bolting thru the shoulder, should I use 2 bolts each side or one larger bolt per side?. ie, I could us 2* 8mm bolts or 1*12mm bolt.
cheers
Old 08-21-2004, 07:10 PM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
MoonDog: You could probably get away with either as there is enough surface area on your mounting pads to resist "rocking" My choice would be 4x 8mm's! (I used the same bearings in my retrofit)
Old 08-22-2004, 07:06 AM
Thanks IJ....
I think I'll go with the 4*8mm's as you suggested.
cheers
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
newbie Quest. Basic Static Load on Linear Bearing Block kNewton ? Calico Linear and Rotary Motion 4 06-27-2007 07:10 PM
Ball screw angular contact bearing block dowling177 DIY-CNC Router Table Machines 0 03-15-2005 03:03 AM
Angular Contact bearing question sendkeys General Metal Working Machines 2 07-12-2004 07:45 PM
Thomson rail and bearing question Darren DIY-CNC Router Table Machines 8 12-10-2003 07:35 PM
