Old 04-20-2008, 01:20 PM
g450pilot is on a distinguished road
Need digitizing help
Hello to the Forum! This place is great.
I'm just starting this hobby/business and have a lot to learn. I have been using a friends CarveWright machine, but see some reliability issues.
I also see some quality DIY machines, but need to know how to digitize an obect so that the router can work. And, how much they might cost.
It looks like I would like to us Mach 3 software, but looking for advice there too.
Regards,
Dave
Old 05-02-2008, 11:40 AM
vinot is on a distinguished road
It depends on kind of object and size.
There are several ways to digitalize:
-touch probe scan: acts as another tool in your router or milling, as accuracy as your router, maybe the most cheap option.
-laser scanner: should be another "machine", even like www.david-laserscanner.com, for me works 100%. Other commercial options should start at 3500usd (?, NextEngine perhaps) up to several kUSD
- scaner arms (Faro and so on), they act as a touch probe but with an arm, also an expensive option.
-photogrammetry, basically for very large objects (buildings, arquitecture...), costs depends on camera/s used, commercial apps are not so expensive (photomodeler works also fine for me)
In my opinion the most easy way is to use a touch scanning in your router: my CAM app accepts direct scans and revert it to the model, so it is a semiautomatic procedure. After this way, the rest could become more teddious and hard, but better results could be achived.
toni
Old 05-02-2008, 05:18 PM
Toni:
Thanks for your reply. It clears up a couple of question since I am new to this.
I think the touch probe will probably work best for me.
Regards,
Dave
Old 05-02-2008, 05:47 PM
ger21's Avatar
There's a guy making inexpensive probes on the Mach3 forum.
http://www.machsupport.com/forum/ind...ic,5004.0.html
Old 05-02-2008, 06:39 PM
I have the mach 3 site on my list, so I'll check.
Dave
digitizing 70cyclone Milltronics 9 11-25-2007 06:40 PM
Digitizing in AUS??? member login Digitizing and Laser Digitizing 5 07-24-2007 12:03 PM
Digitizing raygarrett1 Employment Opportunity 3 05-30-2005 10:31 PM
Digitizing Michael M AjaxCNC Control Products 9 01-18-2005 03:14 PM
3d Digitizing WORKALONE Digitizing and Laser Digitizing 0 04-13-2004 02:23 PM
