I have a 3axis Ahha system with #34 1535 oz/in stepper motors. Right now the system is installed on my knee mill. I have need to change it out, and I was thinking about building a router around the steppers. I want as much precision/repeatability as I can resonably get. So far I have a machine designed, but I wanted to put this out and get a reality check. Plus I have a few questions. The design, 4'x4'x12"(12" for a 4th axis, thicker materials, etc) Gantry style. (I have limited space.) The frame; aluminum tube 4x4 w/.5" walls. I will use tooling plate for mounts and etc. For guides, Misumi linear rails. Sizes ? (Do I need to mill the surface the rails will be attached to?) To drive the bridge, twin preloaded .75 or 1" acme screws, chain sync. For the carriage the same size screws. To move the spindle 3/4 or .5" screw. I'm not sure what to use for a spindle(I'm leaning tward Porter Cable). What is the best way(s) to connect the stepper motors to the screws? I want to add a vacuum hold down system. What is the best way to do this? Any sources fot t-slots out there? I want to work aluminum, is building a machine structure out of aluminum a good idea? Any input would be greatly appreciated. Thanks |
The Porter Cable 7518 is probably the best Router to use, but if you have a big enough budget, a Columbo or Perske (or similar) would be a better option, if you want a lot of power. I think the best way is helical couplers, or timing belts. The belts give you the option of changing gear ratios if you need to. If you can, then I'd mill the mounting surfaces for the rails. It can't hurt.
| While You may have powerfull steppers, you may not be able to use then to your full potential, unless you get a substantial spindle. Its all very well to have speed and power but the feed rate your spindle can cope with, should be your main criteria. You will bog down the spindle if pushed too hard. You realise that you are probably looking in the 3phase specrum for a suitable spindle if you want to use those steppers to full potential. |
| Thanks for the replies guys. Ger21 do you know of a good source for the GT2 timing belts? Right now I don't have the budget for the larger spindles. You never know, I will have to look into it further. I've included a sketch of the machine. Note: I left out the spindle. Hope this works. |
| Have you been to McMaster-Carr's website? That place has just about anything you could ever want (including GT2 belts I'm pretty sure), but don't take my word for it. ![]() Maybe the more experienced folk around here will have a "secret source" for cheap timing belts?
__________________ Personal quote goes here |
| http://www.sdp-si.com for the belts.
Formulas/ratios will do. |
| I think it really depends on what you're going to be cutting. I've never seen a formula to determine. It depends on how fast you are cutting, and how much material you are taking out per pass. Different types of router bits can also make a difference. Chipbreaker bits can cut faster than regular spiral bits, for example. If you find that the spindle can't keep up, you can always make multiple passes. How fast did you plan on this machine cutting? I'd probably go with the PC, since it's about 1/10 the price of anything better, and see how it works out.
| The worst I would throw at it would be aluminum(6061 T6), up to .5" thick. If I take easy I could go a lot thicker. My Bridgeport clone is 3 hp, and I've taken .5" cuts and better in steel. It has a lot of low end power, and cast iron machine and an aluminum machine are very different beasts. How well do do the PC routers hold up to working metals? Do I have to do anything special to the machine, with the router running at such a high rpm? Vibration a problem? Is machining aluminum with an aluminum machine a problem? Or is it more advantageous to build the machine out of steel? |
#10
#11
| Just a side thought, from my personal experience, I've noticed that PC uses larger bearings that many of the other router manufactors in the 3hp catagory. This is one of the reasons this PC router outperform other routers in longevity and should last a bit longer before their bearing eventually fail and have to be replaced.
__________________ -Patrick _____________________________________________ measure twice, cut once - a good rule for everything |
| Finding The Right Router | Crushmonkey | Commercial CNC Wood Routers | 22 | 06-19-2006 02:17 AM |
| Quick built router | CNC Darren | DIY-CNC Router Table Machines | 10 | 06-05-2005 09:09 PM |
| long term stability of wood framed router | dave925 | DIY-CNC Router Table Machines | 17 | 05-06-2005 12:33 AM |
| buscht's cnc router | buscht | DIY-CNC Router Table Machines | 25 | 04-13-2004 12:43 PM |
| My first CNC router: 1.5 years building | hddjohns | DIY-CNC Router Table Machines | 2 | 04-03-2004 11:18 AM |
