Old 04-18-2008, 03:17 PM
osix is on a distinguished road
STarting NEw project - Need Serious Help to Understand PArts before starting
Hi , My name is Max . i;m collecting info and starting to Build a CNC rounter . for mY MDF project ..
First i would LISt my NEEDS -
Cutting Space of 48" x 34 "
Cutting MDF thickness 20-30mm
Basic operation ..
Cutting ODD shape . and letter . as well as engraving of letter and design .
what would i need if i want the machine to work .
6-10 hour a day .
This is my basic needs and of cos i hope what i am building will be durable and lasting .
Here is a FEw Site i am looking at for the Package .
http://www.xylotex.com/
http://www.probotix.com/3_axis_stepp...r_driver_kits/
http://www.kelinginc.net/ThreeXCNCPackage.html
xylotex offer one PCB for the 3 Driver .
which i am thinking if it break down or somehow due to my poor understanding
damage it .. i would have to replace the whole PBC ..
but other .. package offer 3 pcs PCB one for eaqch drive .. which if i damage anyone one of then during testing i can replace only the damage one .
i might be wrong - so do correct me and enlighten me
i see some fancy Stuff like pendant jogger .
which i would be interested , anyone know any seller - for the product and what kinda . setup would i need s.
If you know other site with PAckage Kit -- and you think is A good option to view at please - provide URl thanks you
i have been loooking at kelinginc stuff and a few other package seller out there for the Motor and drive package .. but all this technical term is confusing me ..
So to start off
the Stepper Motor . - what would one suggest .. Servo or steeper -
what kinda Stepper size would i need.
the price diffrent of NEMA 23 seen much cheaper .. would it be enough for my task ..?
IF NEMA 23 is the choice . what Oz would be better . 270oz or 425oz ? the price different is not much .
WHat is a Breakout Board . -????
Can i use USB .. or upgarde in future if i need too .
chances is i would run my System on a Cheap old laptop .running on WIN xp .
I am also having problem to find a LEad screw for my cutting size --
can someone point be a direction ?
more or less i should have no problem making the TAble for cutting .
but the technial aspect on the steeper and computer is a kinda confusing for me .
what would be a good software to use - i am good at illustrator on adobe , but not sure if . 3d is the same ..
if you have package which you think is good or better please kindly suggest and put your reason why .
well i am looking at about 300-500 usd for the 3 axis package . to start off .
and kelinginc seem to be offering alot of parts .
Spindle
base on cutting MDF that is 20-30mm thick .
what would be a stable good spindle - hope to keep price below $200
with lot of option to upgrade or after market parts . some spindle might be good but the drill bits and parts is expensive - i am guessing .
do suggestion . what is good .or what is best for my project .
i am so new to al this please advice , suggestion correct me if am wrong in anyway .
Old 06-30-2008, 03:44 PM
warrenb is on a distinguished road
I think you might be out of the hobby league trying to build a machine as durable as you're requirements. 6-10 hours a day is going to require a very robust machine. And MDF is a horrible material to route because the dust clogs up everything.
I would suggest you look for some good used routers or even a new one. Komo, Thermwood, Gerber, all make wood routers. It sounds like you'll be in a production environment so get yourself a production machine, it will pay off in the long run. Also make sure to get an automatic lubrication system.
If you're just starting out a new business you might want to save your money and until you can afford a production machine send your parts to a local cabinet shop.
Good luck.
Old 06-30-2008, 03:54 PM
Kelinginc is on a distinguished road
Here is some CNC router for your refrence
http://www.kelinginc.net/CNCmachines6090.html
You are build a big CNC router, I would suggest you to use the NEMA 34 package:
A:3 PCS KL-8078 80V, 7.8A Driver
B: 3 PCS NEMA 34-906 oz-in Stepper Motors
C: 1 PCS KL-6515, 65V/ 15A,Unregulated Power Supply 1000W,2
regulated outputs 5Vdc and 12Vdc at 1A
D:1 PCS C10 Breakout board, E-Stop or Limit Switch can be wired
Starting a new laser gantry project MacGyver Laser Engraving & Cutting Machines 11 12-11-2008 05:56 PM
Starting to cut my first Joes 2006 parts aolshove Joes CNC Model 2006 4 11-24-2007 07:48 AM
Starting my winter project davef2f Benchtop Machines 2 11-05-2007 06:14 AM
Starting a new project chuckknigh CNC Wood Router Project Log 7 11-20-2005 07:55 PM
Finally starting on router project ehiebert DIY-CNC Router Table Machines 9 04-10-2004 07:07 PM
