Old 04-18-2008, 03:06 PM
jeffmorris is on a distinguished road
Router bits?
Can I use any router bits on my CNC machine or must I use specific type of router bits?
Old 04-18-2008, 04:30 PM
chazmtu is on a distinguished road
Hi Jeffmorris,
Most people use endmills and engravers but you could use any bit that fits. Though it could take some experimenting to get them to work right. I've been thinking of using small router attachment bits for a dremel to round edges of signs. What bits were you thinking of using and for what types of cuts(pocket, profile, drill, ect.)?
Chuck
http://chuckscnc.blogspot.com/
Old 04-18-2008, 05:51 PM
I use a DeWalt trim router in my CNC machine. It accepts router bits with 1/4-inch shafts. I use Bosch Solid Carbide 1/4 X 1 Straight Up Spiral Double Flute 1/4-inch shaft for now. I'm using Cut2D program. I know that some projects call for different router bits so I want to know if I need to buy specific type of router bits such as Solid Carbide bits or carbide-tipped bits or straight flute bits or spiral bits. I'll be making wooden signs for now.
Old 04-18-2008, 05:58 PM
Different bits make different cuts. More flutes means a better finish for surface milling but at a shallower cut with slower speed. V bits are nice for lettering and picture engraving. Ball end mills add dimension to 3d cuts from bitmaps or 3d models. I keep a small asoertment of 2 and 4 flute carbide router bits 1/8 in a few v-bits 60 and 90 deg. ad a few 1/8 in ball end mills.
Old 05-01-2008, 06:55 PM
Matty Zee is on a distinguished road
I've just finished my router build and was wonering the same question as jeffmorris. So when you say end mills and ball end mills, do you mean like metal working ones for mills? or can you get wood specific end mills? (different rake angles?)
Also, all the V-bits at my local hardware store have a large flat in the centre, can you get ones that have a sharper point?
Cheers
Old 05-01-2008, 07:05 PM
ger21's Avatar
Yes, but they tend to be more expensive than endmills for metal.
http://eagleamerica.com/search.asp?s...cd2=1209686405
www.vortextool.com
http://www.amanatool.com/cnc-router-bits.html
www.onsrud.com
Old 05-01-2008, 08:19 PM
I found out from Lee Valley's website that HSS router bits can be used on aluminum. Suppose I wish to make new aluminum parts for my CNC router, what's the maximum thickness of aluminum, maximum depth of cut, and maximum feed rate? Does that mean that HSS router bits are better for hardwood than for softwood?
Old 05-01-2008, 08:26 PM
ger21's Avatar
HSS router bits are not very good for wood, as they dull extremely fast. As for cutting aluminum, it depends on a lot of factors. Machine rigidity, spindle power, ...Trial and error are your best bet.
Old 05-09-2008, 06:16 AM
Who makes the best but cheap router bits?
Old 05-09-2008, 08:06 AM
ger21's Avatar
You get what you pay for. Best and cheap don't go together.
  #11   Ban this user!
Old 05-09-2008, 09:04 AM
Gir Gir is offline
Gir is on a distinguished road
Do you have any suggestions for where a good price/performance ratio is hit for those of us just trying to get started on a small budget? These curves tend to run exponentially...
Old 05-09-2008, 10:17 AM
ger21's Avatar
I buy all my carbide tipped bits from Eagle-america. And spirals from Vortex. Both links in previous post. With Vortex, buy in quantity to get a 30% discount. Quantity required varies from bit to bit. Add to the cart to see the price break.
Where to buy router bits ronateah Wood Working Tooling 15 09-16-2011 05:03 AM
ROUTER BITS CABSPEC22 WoodWorking 7 01-17-2008 09:35 PM
router bits luther DIY-CNC Router Table Machines 1 09-03-2007 06:50 PM
Yet again about router bits. Konstantin WoodWorking 5 12-08-2006 09:31 PM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
