Hey everyone I'm a DIY person just like most of you but without the knowledge i'm currently working on the electronics portion of my CNC machine since the CNC machine has been built (Needing some improvements in accuracy still) Now with the electronics I have about 30 stepper motors pulled from various things small to big but I don't have 4 of the same anyways I have looked at many posts about electronics and Stepper's and have come close but not all the facts. I have a few questions as too what I should do below and thanks for the help everyone 1) Driver circuit I have seen various kinds and would like one with everything on one board including breakout board must drive 4 axises (4 phase and above are the stepper motors I have) 2) Does the Driver circuit components have to be adjusted for the size of stepper motor meaning amps and volts of course 3) I have Stepper motors that have 2 degrees and less is that good for about +- .010 or +- .005 4) Power supply hoping to use Computer Power supply if it works I've heard of people using them. 5) Can different motors be used on the same CNC Machine (Different one for A axis or Z axis) 6) Mach 3 Setup 7) Hoping to cut light aluminum, plastic, foam, wood, brass (hopefully) stronger materials will be using smaller step down and I will only be cutting small propellers out of brass 8) Source for parts like Printers, Power supply's etc (Can order but would like to find in redly available places) These are only a few questions that need to be answered before i move on Thanks for all the help and hopefully I will be able to get started on the electronics soon and watch my machine work |
Depending on the size of your machine, most printer motors won't be powerful enough. Do you have the rated torque for any of the motors you have? They're pretty much useless if they're under 100 oz-in. You'll probably want to look into dual lead screws, each with their own motor, to maximize your torque. |
| For the Driver Board I would like to Do It Myself as I have all the required equipment and supply's I just need one with adjustable voltages/amps for different motors etc it necessarily doesn't need to have a breakout board part of it bc I can draw one in auto cad and I was only using the possibilities of the Printer for controller IC's or other transistors etc thanks for all the help so far |
| Ok so here are some of the Big Stepper motors I have found over a few years all list the info below Mini angle Stepper(2 of these) (Couldn't find much info on this one) IBM P/N 4703237 Type: 34PM-C124 1.4 ohms/coil 2.8 amps/coil Superior Slo-Syn Type:M092-FD-333 200 oz/in 2.5 v 4.6 amps More Info about products close to this one can't find this one are at http://www.mcsupplyco.com/uploads/pr...ProductID=1205 Superior Slo-Syn(2 of these) Type:M091-BD-3108 110oz/in 180 steps per rev 7.4 v 1.39 amps More Info about products close to this one can't find this one are at http://www.mcsupplyco.com/uploads/pr...ProductID=1205 Step_Syu Type 103-820-0242 IBM P/N 240256 4.5 V 1.4 Amps 200 steps Unknown IBM P/N 1816039 EC357475 Model :GPF4945-2t Step Angle 2 deg 2.8 v 2.2 amps/phase Step_Syu Type: 103-820-0042 IBM P/N :2462561 4.5 v 1.4 amps Ok so I was planing to use the one 200oz one as my A axis because it will be able to hold up the materials better then the smaller ones then use the 2 Mini angle Steppers as the X and Y axises and the Z im not to sure off any help on these Steppers is great as well as if the choice's for each axis are good Now to the more difficult problem finding a DIY Driver board that will work with all these Steppers or even changing one so they will any help on this is greatly needed thanks |
| pros and cons | stirling | Stepper Motors and Drives | 9 | 08-28-2007 09:40 AM |
| A little help from the Pros | robinsoncr | Rhino 3D | 1 | 06-15-2006 12:58 PM |
| Pros and Cons of Two Designs | PaulH | DIY-CNC Router Table Machines | 9 | 10-22-2005 09:22 AM |
| Ask The Pros | ClockMaster | Stepper Motors and Drives | 3 | 08-12-2005 02:33 PM |
| What are the pros and cons of | CNCadmin | CNC Machining Centers | 1 | 05-19-2003 12:31 AM |
