Old 04-15-2008, 07:54 AM
skipper_52 is on a distinguished road
A video of machine to enjoy
Enjoy, I did.
hmmm... if it doesn't show up search for homemade cnc or greggzurek
Old 04-15-2008, 08:43 AM
Sinkoumn's Avatar
Sinkoumn is on a distinguished road
Awesome! Running smooth
Do you have a skirt running around the outside of the dust collector, or is it open? If it's open, how well is that working out in terms of dust control for the cuts?
www.NeustonBoards.com
Mike
Old 04-15-2008, 08:47 AM
Skirt was removed for video. It's a rubber skirt made from landscaping material for ponds.
With it off it collects 80%. On - 99.999%
Old 04-16-2008, 03:50 PM
randyf1965 is on a distinguished road
Is that video at normal speed?
Why does everyone want to put music on their video? I like the sound of the steppers and router.
Old 04-16-2008, 10:03 PM
johnmac's Avatar
johnmac is on a distinguished road
I have the same HF router motor on mine. Mounted the same way, but using only 1 clamp.
I like the speed of your machine. Can you give some specs on how it's driven?
Thanks, John
Old 04-16-2008, 11:07 PM
Speed of video was sped up twice to fit the music. Actual cutting time was 7 minutes but could be cut down to 6 or less. Didn't want to chance chipping the veneer. I listened to enough wood being cut and the vacuum running to give anyone a headache. If I'm going to wear headphones it will have music in it and not a router being run.
Old 04-22-2008, 08:08 AM
Opinion needed. If a larger machine was to be built, would it be best to build the frame from steel or wood. I'm getting equal opinions but need yours. 50% or so say that the wood beam and frame helps absorb noise. Last machine doesn't have enough clearances for a 4th axis without extending the legs between the table and the machine. Also I'd likt to mount a 3hp Freud router so I can use all the bits I have.
Old 04-22-2008, 06:28 PM
johnmac's Avatar
I have rails, screws, motors and drivers for my next build. It will be a 36 x 48 inch bed with 8 inches of Z travel. I will be building a steel frame so I can weld most of it.
John
First Machine Almost Done - Pics + Video tvdbon Rockcliff Machine 11 01-12-2009 09:41 AM
Video of my TRON machine jensn DIY-CNC Router Table Machines 1 05-12-2007 04:52 PM
Video of my machine. It will take a while to display. ynneb General Metalwork Discussion 10 08-12-2004 04:01 AM
CNC machine video CNCadmin DIY-CNC Router Table Machines 10 11-19-2003 08:46 AM
