Old 04-14-2008, 01:12 PM
skipper_52 is on a distinguished road
Turning on a cnc router.
I'm going to assume that this is out there somewhere but need directions to get there. I want to disconnect my Y axis cabling and reconnect it to a servo driven rotary indexer/lathe. Does anyone know where to get plans or pics for this attachment and has anyone done this with Mach 3. The idea is to turn arbors for clocks.
Old 04-14-2008, 01:50 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Why not just setup the indexer as 'A'nother axis?
Paul
Old 04-14-2008, 01:59 PM
Ahh... hindsight would have made me purchase a 4 axis card.
Old 04-14-2008, 02:39 PM
I see. Well then, if your using Mach3, I would setup a different profile for using your Y axis as your A axis. Then all you have to do is switch wires and select the correct profile.
RFQ - 304 SS Turning Job JMFabrications Employment Opportunity 1 10-31-2007 09:23 AM
turning 304!? kperk12345 General Metalwork Discussion 3 09-12-2007 08:47 PM
Turning camtd SolidCam 1 08-01-2007 12:40 PM
Turning S7 vs. D2 wildcat General Metalwork Discussion 1 07-06-2007 09:06 AM
non-circular CNC turning. oldguy General Metal Working Machines 2 04-21-2004 08:52 PM
