Old 04-14-2008, 10:33 AM
Marwell is on a distinguished road
Drive Nut and threaded rod.
Howdy all,
I finished my router about 2 weeks ago, the table is 16 X 32, cutting area is approximately 14 X 26. Runs nice using Mach 3 and Vectric Software.
The only issue am having is that I think I am getting too much drag on the leadscrews. I am using 1/2" - 10 Acme threaded rod and brass nuts. Does anyone have any suggestions as to a decent replacement. I would like to keep it to around the 1/2" mark.
I do not want to sink too much money into the system as I plan on buying a full size 48 x 96 machine in the next 6 months or so. I will keep this one as a standby and for smaller jobs.
Old 04-14-2008, 10:50 AM
Thazul is on a distinguished road
I use 1/2"-10 acme screw on my Z Axis with a homemade delrin plastic nut, it works great.
I'd like to get a little more speed though, I'm thinking of switching it to 1/2"-8 2 start.
Check out some of the Joe's CNC builds, they're using 1/2"-8 2 start, and 1/2"-10 5 start screws with these Anti-Backlash nuts:
http://www.dumpstercnc.com/leadnuts_acme.html
1/2"-10 = 0.1" per rev
1/2"-8 2 start = 0.25" per rev
1/2"-10 5 start = 0.5" per rev
Andy
Old 04-14-2008, 05:24 PM
johnmac's Avatar
johnmac is on a distinguished road
Delrin nuts are the way to go. Dumpster CNC is as good a place as any to get them. Don't let the "plastic" part scare you.
John
Threaded Rod Post1952 Joes CNC Model 2006 2 05-12-2007 10:28 PM
Cant get threaded rod straight. Fodder1 JGRO Router Table Design 16 05-23-2006 10:44 PM
Threaded rod. Max-DK DIY-CNC Router Table Machines 17 03-30-2006 11:28 AM
Direct or geared reduction to threaded drive ? (stepper) andy_ck87028 Linear and Rotary Motion 4 03-13-2006 07:42 PM
Using threaded rod for drive screws DieGuy Linear and Rotary Motion 1 07-11-2005 08:50 PM
