I have noticed on the forums over the years. The base table pretty much is a dead peace or like mechmate states "The big non-moving part". Seems like most bases are fairly similar with a little modification here and there to fit your XYZ axis. So, I figured I would create this thread to throw around ideas to keep the cost way down for the most dead peace of the project. I assume welding it would be cheaper than bolting or epoxy. I welded back in high school (a long time ago) but I don't know how much steel is...or there is unistrut. Maybe, We could find cheap alternatives for the various methods. So, if we could give ideas...plus, the costs (BOM). Maybe, we can come up with a nice solid cheap Metal base table that would work for everyone. Whether you scale it up or down. The cost would still be cheap based on the total cost of the project. Myself, I am looking at 4x4 but it could work for any size... So, any ideas? |
| how about this...any way to make a base table for under $200 ? Has anyone done this? What was the cost of just the base table for some you? I was looking at this site: http://www.simplifiedbuilding.com/pr...ench-shelf.php Though they are really expensive. I was thinking of using a larger black gas pipe like this guy did: http://www.jbbritton.com/irondesk/index.html and just using the basic connection pieces sold at HD/Lowes. Would it support the weight? Last edited by billman; 04-12-2008 at 04:52 PM. |
| Square or rectangle steel tubing is going for about $.80/lb, slightly more or less depending on the size. My table is made of 4" x 2" x 14 ga, approximately 60"l x 60"w x 30"h. Without the material supports it weighs 100 pounds. So that's $80 for steel to build a rather stout table. Mine is fully welded, and I see no reason not to weld it unless you will need to take it apart for some reason, or you don't have access/don't know how to use a welder. |
| A cheap source of relatively straight steel is used pallet racks -- I've thought about making tables out of those for some time. Only problem is the uprights are usually 16' + tall, which makes them somewhat inconvenient. If you chopped the uprights to workbench size (keeping at least one diagonal brace) and then got some of the bolt-on C-channel beams, you'd have a pretty stout framework as well. It's a thought... Ahren www.cncrouterparts.com |
| I bought new steel and inmo I paid too much. After I got stuck into the project, I found a scrap metal merchant where the metal on offer was much cheaper and a lot heavier. Welding is definitely the way to go. You might find scrap with a useable frame. A while ago, I was driving to work and a hospital was chucking out a fully adjustable hospital bed. I could have salvaged a heap out of that but I know my missus would have thrown a fit. I reckon the base frame should cost you buttons. Its a pity for my pocket that I didn't learn that earlier. Andy
__________________ Drat, imperfection has finally stopped working!! |
| I should add that the steel price I posted is new clean steel up to 22' lengths, any size or thickness you want. Flats are cheaper than tube, ~$.58 per pound for 1/4" x 2" (<$1 per foot). http://www.hooversteel.com/ I also buy from a surplus/salvage yard where all steel is currently $.40 per pound any size or shape, but you have to work with whatever they have and it might be a little rusty. They always have a couple standard sizes of tubing, angle, and sheet. The place I go to also has lots of used industrial machines to pick over. If you can find a place like this local to you, you'll feel like you've found a gold mine. |
| Great Ideas. I did a search on the internet for local pallet racking and found some Uprights 17'H x 38.5"D (3"x1.5") for $50. Plus, beams 144"L x 4"H for $16. Uprights already have extra supports in place too. If you laid horizontally could work but would have to cut them down to size on site. Plus, no idea on the weight for my little pickup to carry..yikes! |
| Low Cost Metal Frame Router | mlaws1172 | Open Source CNC Machine Designs | 74 | 03-10-2008 09:08 PM |
| Pics of my metal cnc table (base w/rails complete) | guru_florida | DIY-CNC Router Table Machines | 7 | 12-14-2007 05:12 AM |
| An IH build, base to table | ozzie34231 | Industrial Hobbies (Support forum) | 6 | 05-31-2007 05:05 PM |
| Mobile base for the IH: any ideas? | deaeni | Industrial Hobbies (Support forum) | 0 | 07-30-2006 08:25 AM |
| Low Cost Ideas or Experiences? | coherent | DIY-CNC Router Table Machines | 13 | 05-10-2003 03:22 PM |
