Old 04-10-2008, 05:19 PM
BlkNotes is on a distinguished road
Exclamation Mach & cnc router interface problems
Hello;
I was wondering if someone could help me. I am setting up a cnc router to mach3mill demo version to test out. I have a mechatronic 3 axis board. I have it connected via parallel port to my computer but cannot get any movement of the router. I am not suring if it is the parallel port that is not being recognized or transmiting info or if I did not set the initial parameters for Mach properly ( i.e. ports & pins--input /output, motor tuning parameters)
Also could someone direct me to easy to understand mach mill explaination & implementation tutorial etc..
Thank-you
BN
Old 04-10-2008, 05:22 PM
ger21's Avatar
First, check the port address. Then check that each pin is assigned to port 1, and not port 0.
Do the DRO's on the screen move when you try to jog? If so, check the voltage on the direction pin at your board. It should change from 0V to 5V when you change directions.
HELP!! Heidenhain PC interface Problems servocontroller Bridgeport and Hardinge Mills 4 06-11-2009 06:05 AM
Mach 3 interface to stepper motor driver dhookings Machines running Mach Software 6 06-11-2009 04:11 AM
Need Help!- Interface problems with TNC 151 bigred Bridgeport and Hardinge Mills 9 11-08-2008 03:37 AM
Need a tach sensor to Interface with Mach 3 dneisler General Electronics Discussion 1 11-26-2007 04:38 PM
Problems with demo of Mach tt_raptor_90 Mach Software (ArtSoft software) 5 05-24-2006 10:31 AM
