Old 04-10-2008, 02:15 PM
mcjones22 is on a distinguished road
Why is my circle not round?
I've built a JGRO router and am using Mach 3. I'm currently testing the machine and am able to cut squares from 19mm mdf with great accuracy. When cutting a circle each cut is perfectly circular however each new cut is slightly offset from the last. This results in a stepped oval shape on one side and circular on the other.
My squares are perfect but my circles are far from perfect. What can be wrong - any suggestions?
Old 04-10-2008, 02:31 PM
Gir Gir is offline
Gir is on a distinguished road
Sounds like you may be missing steps. Make sure all the bearings and lead screws are aligned properly and the gantry and can move smoothly.
Old 04-10-2008, 08:20 PM
metalworkz's Avatar
metalworkz is on a distinguished road
Make sure all of the connections between the motors and leasdscrews/ballscrews are tight. Even a little movement at the connections will be obvious as the axis reach the end of the direction move at 90 degree intervals.
Regards,
Wes
Problem cutting a round circle Sandor_nl Laser Engraving & Cutting Machines 3 02-14-2008 07:43 AM
Milled Circle Not Round? b0gh0s Benchtop Machines 24 12-01-2007 08:16 PM
The Perfect Circle - Need Help ScoobyDoo FeatureCAM CAD/CAM 11 01-17-2007 04:41 PM
Repeated circle not round. SCCoupe DIY-CNC Router Table Machines 17 07-19-2006 09:32 PM
Text around a circle tsalaf Rhino 3D 2 09-24-2003 10:33 AM
