Old 08-13-2004, 09:18 PM
Clyde is on a distinguished road
Yet another first router
I finally got this thing going..............I think I like it
I'm using Nema 23 motors (PK266-1A for Z, PK266-E2.0 for X & Y), gecko drives, homeade parallel port box, etc.....
Old 08-13-2004, 09:23 PM
Yet Another First Router
The actual work area is 17.5" x 36".
180 IPM, using ACME 1/2x10 as drive screws, nylon as drive nuts.
Thanks everyone, for the information on this site, I found it to be very useful!
Old 08-13-2004, 09:32 PM
duluthboat's Avatar
duluthboat is on a distinguished road
Thumbs up
Very Nice.
Gary
Old 08-13-2004, 10:15 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Very nice overall! and I add. a VERY Nice mount for the router!
A little anodized aly and plastics in that? Looks like a stout rig.
CHEERS - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 08-13-2004, 11:43 PM
CHEERS - Jim
Yes, it's UHMW and a cam lever from Rockler Woodworking supply.
In the above pics, I also have a block of 3/4" MDF where the 1/4x20 socket cap screw mounts the router from the back. This evening I built a replacement for that block that will have four 1/2" holes in the bottom edge that route to a mount on the right top side for a 1" vaccum hose for dust collection (a dual purpose fitting).
This has been a long project (~3 months). I bought a mini mill and mini lathe and began learning how to use them (of course the expense is not in the equipment but in the collets, end mills, boring outfits, on and on........).
I modeled the entire project in Rhino3D (some at the start, some as I went along). I didn't mill, drill, tap, or cut until I knew how it was going together. That helped alot in _not_ having to redo stuff. I drilled and tapped some of the plates in pairs (bolted together) to reduce the work.
For some of the larger plates and channel (larger than my mini mill could handle, 11"x23"x3/8" plate on the gantry and 48" long channel for the X rails), I built a device using 3/8"x16 allthread that allowed me to get accuracy on the drill press for drilling and tapping. I know that others must run into these problems with needing to drill (and or tap) long pieces accurately. I handled it with a homade jig. I even milled a ruler for it into 1"x1/8" aluminum angle.
Old 08-14-2004, 09:16 AM
arvidb is on a distinguished road
What's with those motor mounts? They look really cool , but are there any other reasons for the way they look?
Overall very tidy and nice!
Arvid
Old 08-14-2004, 11:20 AM
DR-Motion's Avatar
DR-Motion is on a distinguished road
Nice work Clyde,
"The actual work area is 17.5" x 36".
180 IPM, using ACME 1/2x10 as drive screws, nylon as drive nuts."
Is this a typo?
180 IPM equals 3 inches per second... which means your motors have to spin 3 inches x 10 revolutions per inch = 30 revolutions per second or 1800 RPM... that's fast! ... especially under load.
Gary
embrace enthusiasm to accomplish the task
Gary Davies... www.durhamrobotics.com
Old 08-14-2004, 11:53 AM
I made the motor mounts like "Heat Sinks" to help keep the motors cool, don't know if this is necessary, but thought I'd give it a try.
The 180 IPM is jog speed, the motors (oriental motor PK266-E2.0) can run at 2000 RPM (used on X and Y).
I had problems with vibrations in the X ACME screw (~48" long) at high speed, so I made a dampener yesterday (not shown in the above pics) out of UHMW that applies slight pressure on the screw about 2" away from the nylon nut on either side, and it worked great!
Old 08-14-2004, 10:46 PM
I learned at least one thing today:
The accelertion/deceleration values are as important as the cut feed rate for performance. I hadn't really thought that much about it until I saw the router run yesterday. During short runs with changes in direction or axis emphasis, accleration played a big role in the actual cut rate. So I up the acceleration (still might up it a bit more).
Lots more to learn............
Old 08-14-2004, 11:18 PM
Kerri Ann is on a distinguished road
wow Dad, nice job
maybe soon I'll know what exactly all that stuff means....
  #11   Ban this user!
Old 08-15-2004, 10:43 AM
jimbo is on a distinguished road
nice machine, any problems with the leadscrew driving from one side as on the x axis?
  #12   Ban this user!
Old 08-15-2004, 04:55 PM
Graham S is on a distinguished road
Nice machine!!
What is the white base made from?
Have you had any problems driving the axis on one side only?
Graham
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 11:12 PM
Finding The Right Router Crushmonkey Commercial CNC Wood Routers 22 06-19-2006 02:17 AM
Quick built router CNC Darren DIY-CNC Router Table Machines 10 06-05-2005 09:09 PM
long term stability of wood framed router dave925 DIY-CNC Router Table Machines 17 05-06-2005 12:33 AM
my new longbed router cncspear DIY-CNC Router Table Machines 16 10-15-2004 09:36 PM
