  #13   Ban this user!
Old 08-16-2004, 12:03 AM
Clyde is on a distinguished road
Yet Another First Router
I haven't had any problems with driving the gantry from one side, yet.........I have only cut 3/4" MDF so far in my tests, but up to now it is solid.......It is 23" from center to center of the thomson rails for the x axis.
THE WHITE BOX that the x rails and channel are sitting on is 1/2" MDF torsion box 5" tall, 34" x 60" (WxH). I read a reply in a thread here somewhere about DIY having a show on it, so I looked it up on DIY's web site and decided it was a good thing, and it is very very solid. I built mine a different way than they suggested.........but still a torsion box all the same.
I would have built the box with some options built into it before it's assembly if I had it to do again............one, I would like to have had wood blocks in the corners for mounting legs............two, I would make sure I kept my measurements of where exactly the internal supports were (horizontal and vertical honey comb like supports)...........three, I would have relieved the internal supports by drilling large (2.25"?) holes in them so that air would flow easily throughout the inside (for dust collection purposes, and It would have been lighter, I can barely handle it by myself with nothing attached to it)........four, I would like to have put PVC pipe through it in strategic places to run wires around internally..............planning ahead to that detail would be quite a task, but probably worth it..............
  #14   Ban this user!
Old 08-16-2004, 12:24 AM
Yet Another First Router (Torsion Box Base)
The attached pic shows how I built the torsion box............
  #15   Ban this user!
Old 08-16-2004, 03:39 AM
Graham S is on a distinguished road
I thought as much, it just looked solid!!
Old 08-16-2004, 06:32 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Might add, "....."five, consider the box as a plenum for a vacuum mount system....
Looks great and the torsion box is a real good idea - Did you use smaller (thinner) dimensioned MDF for it - suppose you could have and still be plenty rigid.
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  #17   Ban this user!
Old 08-16-2004, 10:05 AM
Yes, I used 1/2" (instead of 3/4) MDF throught the torsion box.........it is plenty sturdy!
Today, I have to start on building 2 guitars that were ordered, so I must pause a while on finishing the cabinet that the torsion box sits on (only the frame is complete, have to add draws, enclosed area for computer and driver box, etc............).
  #18   Ban this user!
Old 08-16-2004, 10:54 AM
InventIt is on a distinguished road
Very nice job.
Like the motor mounts with cooling fins, good idea.
Old 08-16-2004, 11:03 AM
svenakela is on a distinguished road
I'm using the same idea of sandwich layed up table as your torsion box, but with aluminium in three layers. Almost as strong as a solid plate but almost half the cost and of course less weight.
Forgot: your machine looks really nice!
Cheers,
Sven
Last edited by svenakela; 08-16-2004 at 11:06 AM. Reason: Forgot to say: your machine looks really nice!
  #20   Ban this user!
Old 12-01-2004, 07:41 PM
napalm03 is on a distinguished road
nice machine Clyde, I like the heat sinks on the steppers, they do get very warm if you over power them, I have some on my taig mill and they get almost too warm to touch somtimes. I'll make my mounts a heat sink like yours, very novel idea! What kind of rails are you using? Are you able to cut alum plate?
  #21   Ban this user!
Old 12-02-2004, 08:46 AM
"What kind of rails are you using? Are you able to cut alum plate?"
The rails are Thomson 1/2" with single and twin open pillow block bearings.
I have cut some aluminum, although that was not my primary goal.
I'm using the machine to make pickguards for my own electric guitar model at this time. I hope to use it for other repetitive routing on the body in the near future (have to model it in Rhino3D yet).
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 10:12 PM
Finding The Right Router Crushmonkey Commercial CNC Wood Routers 22 06-19-2006 01:17 AM
Quick built router CNC Darren DIY-CNC Router Table Machines 10 06-05-2005 08:09 PM
long term stability of wood framed router dave925 DIY-CNC Router Table Machines 17 05-05-2005 11:33 PM
my new longbed router cncspear DIY-CNC Router Table Machines 16 10-15-2004 08:36 PM
