I'd like to get into 5/6 axis machining of small wooden toys. I really like the Romaxx CNC 3 axis machine. It's just about the right size for what I want to do. My question for y'all out there: Can I add onto the Romaxx machine easily enough by buying additional drive units from http://www.doughtydrive.com/ and controlling these extra axes with a separate control box? The Romaxx machine says that it is ready to plug right into a PC, so they must have built a 3 axis control board into the machine. Therefore, I'd have to supply a separate 3 axis control enclosure for the A-B-C axes. I'm pretty sure that Mach-3 can control 6 total axes. If that is the thing to do, how do I connect both the Romaxx machine AND this extra drive enclosure to my PC? Thanks in advance for any advice! |
| You can build a 2nd 3 axis controller & run it on MACH3 as LPT2. You will need a good LPT2 port card that will put out 5VDC, some don't. You may want to check your Z axis height as I don't think it will fit in the space. Skip20 Knoxville |
| Romaxx | lovebugjunkie | Commercial CNC Wood Routers | 22 | 01-29-2009 07:35 PM |
| Adding a fan to the X3 | Antonyong | Benchtop Machines | 2 | 04-25-2007 11:19 PM |
| Adding a Joystick. | on7tim7 | Mach Mill | 0 | 01-10-2006 01:33 PM |
| Adding a 4th | Shizzlemah | Fadal | 5 | 12-01-2005 05:16 PM |
| adding a longer bed | balsaman | Mini Lathe | 13 | 04-09-2004 09:31 PM |
