Old 08-09-2004, 05:59 PM
*Registered User*
landart is on a distinguished road
Cutting balsa ribs - What type of bit to use
Iam trying to cut some balsa ribs for a plane project. I am was wondering if anyone could suggest the type of bit I could use on my porter cable mounted router..Iam usin a 1/4" collet. I have pre drawn the files with a .0625 offset to use a 1/8" bit. I ve cut some test ribs and they come out kinda fuzzy. thanks for the help..Jim Stidham
Old 08-09-2004, 06:28 PM
ger21's Avatar
try a 1/8" downcut spiral. You can get them with 1/4" shanks from just about any router bit manufacturer.
Cutting balsa and ply markdib Parts for Radio Control Models 27 07-26-2010 11:38 PM
Vee Cutting Bit ljoe1969 DIY-CNC Router Table Machines 6 08-02-2004 03:28 PM
Cutting bit questions CNCadmin General Metal Working Machines 11 02-20-2004 03:12 PM
Cutting aluminum with an end-mill bit camfambmw5 CNC Machining Centers 9 02-08-2004 05:59 PM
Question about cutting balsa wing ribs Heliboy247 Parts for Radio Control Models 1 05-28-2003 06:11 PM
