Old 08-07-2004, 03:16 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
Painting MDF
I asked a question in one of my other threads about painting MDF. The general consensus was to paint it with the Rustoleum brand Hammered finish paint.
Today I was out on the Rustoleum website looking around and came upon an epoxy paint used for appliance finishes. You know, the really tough paint they put on refrigerators?
http://www.rustoleum.com/product.asp...ct_id=33&SBL=1
There is the link...
Can you guys tell me if this would be a good paint to use or should I stick with the Hammered finish stuff?
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
Old 08-07-2004, 04:48 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
mvaughn - Mark
I'll let you know in a bit.
You prompted me to try the 2 out in a side-by-side comparison - I just laid down some of the Kitchen Epoxy (black) - had a little in a can. I can say it makes tired old range hoods look brand new.
I noted the first coat of the epoxy shows a lot of the MDF "mottled" look underneith - we'll see after a couple of coats if it fills in. I did not prime the MDF - so that will account for the skuzz in first coat.
When the epoxy dries - I'll put a coat of the hammered (silver) next to the black - shoot it then down load the photos - lalalala
- maybe a few hours if you can wait that long!
so grab a Beer, and
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 08-07-2004, 05:20 PM
mvaughn's Avatar
Moderator
Wow!
Jim your reply is above and beyond what I expected.
I look forward to the results.
Cheers
Mark
Old 08-07-2004, 06:14 PM
sendkeys is on a distinguished road
Old 08-07-2004, 07:18 PM
High Seas's Avatar
Gold Member
Thumbs up
No worries Mate - had to take a break and watch Jon Krackauer on Everest again - tooooo cold.....
OK here are the results :
NOTES:
1. No Primer or Prep so its a make it easy as you can comparison!
2. No care about dust. spray boogies, etc. EASY again....
3. The Epoxy Spray was 3 coats - very wet - heavy lay up, but I kept out sags (lucky I guess). Do it outside and wear a mask! Let it tack dry between coats. Set up very hard.
4. BUT - for simple and smart application - I'd go with the Hammered - that's one coat in the photo --with a cheap foamie brush - minimal VOCs (no mask required) and toss the cheapie brush in the bin when you're thru. Mind you - you can vary the lay-up and size of the hammered effect with multiple coats - but hey - Its MDF - not a CAR!
Jim
Last edited by High Seas; 08-07-2004 at 09:30 PM. Reason: typos and make better sense!
Caution building with MDF DJ Morrow Safety Zone 16 01-30-2007 09:28 AM
MDF CNC Machine Progress victorbl CNC Wood Router Project Log 61 03-26-2006 09:39 PM
MDF with Plywood spalm WoodWorking 14 11-14-2005 06:45 PM
MDF Machine - Cut Aluminum? JavaDog DIY-CNC Router Table Machines 7 11-10-2004 01:05 PM
MDF Finishing Question The Wizard DIY-CNC Router Table Machines 3 10-31-2004 10:29 PM
