Old 03-22-2008, 01:14 PM
jksiew is on a distinguished road
Concept for Five Axis Mechmate with 1000mm Z Slide
Hi everyone at the forum, I am newbie here I designing an Five Axis Mechmate with 1000mm Z Slide.
I am not an engineer and have not build any CNC mechine before.
I would properly need a lot of support from all the CNC gurus here.
Feel free to comment before I do something crazy.
See the link below :-
http://s303.photobucket.com/albums/n...=nav_tab_album [/url]
Thank You
JK Siew
Old 03-23-2008, 06:28 PM
Eson's Avatar
Eson is on a distinguished road
Link doesnt work!
Old 03-23-2008, 08:46 PM
Try this,
Jk Siew
Old 03-26-2008, 11:29 PM
harryn is on a distinguished road
I will avoid commenting on the "crazy" part as I have taken on several "interesting" projects over the years.
For my own project (still in motion) I found it useful to not focus on what machine I wanted to build, but instead, what I wanted the machine to be able to make. Once I wrote this part down in detail, as well as what tools / machinery I had access to for building it, then the direction and size started to gel.
It is not necessary, but a useful idea for such a large system is that the distance between rails should be not much more than 2 - 4 X the distance it is supported. An example would be that if your Z axis is 1 meter long, then the supporting bearing lengths should be not less than 1/4 of that, and ideally 1/2 of that to make it really stiff.
Do you have a plan on how to align it / specs for accuracy ?
The software (CAM) would seem to me to be the biggest challenge, at least cost wise. Maybe you already have that under control. I assume it is for foam cutting ?
Introducing the "full-size" MechMate router Gerald_D DIY-CNC Router Table Machines 68 08-24-2011 06:17 AM
slide and ballscrew assy concept ( what do you think ) landy Linear and Rotary Motion 5 01-18-2008 11:09 AM
Taig 4th Axis Concept nattyone960 Taig Mills & Lathes 0 11-17-2006 03:02 AM
Concept Z axis duluthboat DIY-CNC Router Table Machines 46 01-26-2004 07:42 AM
