Old 03-16-2008, 05:17 PM
thomasnc41 is on a distinguished road
CNC Router - Foam/Wood Working
Currently building a CNC Router, 40" x 30" working area. Ordered a package from KelingInc , Acme 1/2 10 2 start lead screw from McMaster and Dumpster backlash nuts. Using an old computer case to hold electronics. Also going to run with Mach3. This is my first time at building one but I am sure am enjoying it.
In the photo's you might notice that I am using 4 wire trailer disconnect to go to the stepper motors. I wanted some way to quick disconnect from the electronics. Has anyone used this method before or is there anything I should be concerned about?
Any comments, good or bad are welcome..............Thanks, Tom
http://www.bennion.net/router/index.html
ID:	55633   Click image for larger version
ID:	55634   Click image for larger version
ID:	55635   Click image for larger version
ID:	55637   Click image for larger version
Foam & Wood milling machine perolalars DIY-CNC Router Table Machines 0 04-11-2007 11:42 AM
I am looking to buy a router. Working or not. runinbymdnt DIY-CNC Router Table Machines 1 12-30-2006 08:46 AM
Foam router KrashKing405 CNC Wire Foam Cutter Machines 0 12-25-2006 05:51 PM
Looking for cutting speed and feerate data in wood and foam Trimix DIY-CNC Router Table Machines 1 01-20-2004 08:20 PM
WOOD WORKING SHOW IN CALI cadcam Trade Shows and Events 1 07-08-2003 01:08 PM
