| The frame of my CNC is made of MDF and I was wondering if I should run a ground wire to my motor bases, linerar bearings and the metal portions of the machine? Thanks |
| That is one problem with a MDF constructed machine, personally I would bond all metal parts together, and connect to a common ground plate. I use this method in general and do not have any problems, I also ground power supply grounds and make sure the service ground is on it. Al.
| 5'x 9' CNC ground up. | gurvy | CNC Wood Router Project Log | 15 | 11-04-2008 01:15 AM |
| Ground Up | jabuffi | Mechanical Calculations/Engineering Design | 0 | 10-14-2006 02:09 PM |
| Motor supply ground vs Logic ground? | Gashmore | General Electronics Discussion | 11 | 06-07-2005 05:21 PM |
| Power Supply ground question | chas | Gecko Drives | 5 | 04-16-2005 06:48 AM |
| To Ground or Not to Ground | Mr.Chips | Xylotex | 1 | 05-01-2004 11:05 PM |
