Old 08-01-2004, 01:16 AM
chas is on a distinguished road
Thrust Bearings
Not completely sure how a typical thrust bearing
assembly would look like. Does anyone have a
cad drawing to enlighten me.
Old 08-01-2004, 06:37 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Maybe this helps - a quick rip from Mcmaster's catalog (more at: www.mcmaster.com)
Cheers - Jim
Name:	thrust bearings.jpg‎
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 08-01-2004, 07:19 AM
sendkeys is on a distinguished road
Old 08-01-2004, 08:16 AM
ger21's Avatar
Are you talking about for a leadscrew? Check out these: http://www.nookind.com/endmount/EndMountsFlange.cfm
or here for a home made version: http://www.5bears.com/cnc04.htm
Old 08-02-2004, 02:25 AM
So to ask a stupid question, they go between the end of the leadscrew(stepped edge)
and the bearing, opposite end from the step motor?
Old 08-02-2004, 04:03 AM
well thrust bearings goes
screw-thrust-bracket-thrust-washer-nut-coupler to servo/stepper
and frist thrust is smashes in the middle of the screw edge and bracket
the bracket is just little bigger then the screw so it can turn free or maybe use a smaller normal bearing(cheaposkate bearing ect) in the middle of the two thrusts and tight on the bracket. this would give you more up/down support. just make sure it doesnt touch side to side only up/down. Like use .3 inch thick bearing and .4 inch bracket ect
then last thrust is smashes on the bracket and washer/nut
i bet in the end this will cost you more then angular contact bearing.
like on the two above websites.
http://www.bearingsdirect.com/cgi-bi...art.cgi?CAT=55
Old 08-02-2004, 07:09 AM
ger21's Avatar
You can make a bearing block like I linked to above using rollerblade bearings, instead of angular contact (which cost a fortune). They won't last as long as angular contact, but they are a fraction of the price and can easily be replaced when worn. And for small routers, they should still last quite a while.
Old 08-02-2004, 07:29 AM
http://www.vxb.com/miva/merchant.mv?...NGULAR_CONTACT
""Ball Bearings 17x40x10
Single Row Angular Contact
Axel Bearings
Lot of 10 Bearings ""
for 19.99 cheapest i seen center hole might be to big but for that price you can turn some smaller centers for it hehe
Old 08-02-2004, 08:04 PM
Patrick2by4's Avatar
Gold Member
Patrick2by4 is on a distinguished road
I guess these would be called angular contact bearings
Name:	Resize of IMG_0711.JPG‎
ID:	3000   Click image for larger version
Name:	Resize of IMG_0710.JPG‎
ID:	3001   Click image for larger version
Name:	Resize of IMG_0709.JPG‎
-Patrick
_____________________________________________
measure twice, cut once - a good rule for everything
Old 08-02-2004, 08:17 PM
HuFlungDung's Avatar
Moderator
Those be tapered roller bearings. Nothing wrong with using those on a low speed app. The principle of having to preload the bearings in pairs, to achieve proper running performance, is the same thing as you'd have to do with real angular contact ball bearings. Angular contact bearings use balls, not rollers. The "angle" of an angular contact bearing is the imaginary line of contact of the ball through the inner and outer races. Its not radial contact, but a few degrees off each side of the radial contact point. There, is that enough to muddy the waters up good?
Old 08-02-2004, 08:42 PM
Gold Member
I will be using these bearings on my y-axis. It will be spinning about 600~800 max. Hopefully I won't have any problems.
-Patrick
Old 08-02-2004, 08:43 PM
High Seas's Avatar
Gold Member
I'm confused? So let me review, what is the question:
Originally Posted by chas
So to ask a stupid question, they go between the end of the leadscrew(stepped edge) and the bearing, opposite end from the step motor?
ANSWER
First: Not a stupid question.
Second: Yes, they can go at the opposite end of the motor - and you'd probably want a bearing that works in both lineal (along the rod direction) to support the rod pushing against the end plate, and radial (around the rod) supporting the shaft as it rotates.
Third: The angular contact looks like a good alternative - and the other thrust bearings have their uses as offered - does that help any?
Forth: Personally, I'm looking at the lower cost filled nylon bearings for the far end of the rod, and just keep a few on hand and replace as needed. I like the 5bears approach too. Hadn't considered beadings at the motor end - so this has all given me something to think about. Thanks guys!
Jim
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Mini-mill x-y thrust bearings? rustyolddo Benchtop Machines 5 07-22-2004 09:11 PM
Are VXB.com bearings good? Evilness DIY-CNC Router Table Machines 7 07-15-2004 11:39 PM
Thrust bearings CactusChip General Metal Working Machines 8 12-26-2003 12:37 AM
Thrust Bearings ToyMaker DIY-CNC Router Table Machines 2 07-06-2003 11:24 PM
